I have a gas line and filter question.... The original tank was loaded with rust, the guy put two inline filters before the pump. I replaced the tank, and am replacing the line to the fuel pump, the line going to the carb is steel and real nice. SO lets here some recomendations. Do I run a line from the tank to the pump, then cut the steel line from the pump to the carb for a filter? or do I put the filter in the rubber line before the pump? leaving the steel line untouched? I have never been a fan of a filter before the pump. I like them on the pressure side. The truck had a bog on take off, probably because of everything I just mentioned. Its the priginal 6 Overhead valve engine. (not flathead) Give me feed back please
I've never been a fan of cutting nice original steel lines just for a filter, and that Cost Clipper 6 isn't going to draw much fuel- I would filter it before the pump and keep a spare in the glovebox
