1952 Chevy Styleline Deluxe BelAir 2-door Hardtop. The engine is a '56 235 straight 6 that does run, but the carb needs rebuilt (leaks). New spark plugs, fuel lines, fuel pump, ignition switch with keys, and ignition coil. The car starts and runs fine but needs a master cylinder to be drivable. Original 3 speed manual on the tree with torque tube rear. A complete car, with most of the original stainless trim included. (Missing one piece of beltline trim and rear window trim). Includes brand new (not installed) rocker panels as well. This car was originally light blue with a grey top (now in old primer) and still has the blue interior. The upholstery was redone at some point and could use a good cleaning, but the seats are in good shape and not torn up or ripped, etc. The door panels need re-done or replaced but are included. This car also includes a Fenton dual-carburetor intake and split (dual exhaust) cast iron headers from Speedway Motors. Needs: *carburetor rebuilt (leaks gas) *floor pan work (rusty) *master brake cylinder *drivers-side window glass needs replaced (vent/main/qtr) - all cracked but do roll down *passenger-side window glass needs replaced (vent/main/qtr) - all cracked but do roll down *Note: The 2 piece front windshield and 3 piece rear (wrap-around) windshield are in decent shape and are not cracked, but do have some slight discoloring. *Carpet , the original carpet was cut up to get at the floor pans and was in bad shape. Has Newer: *clutch *tires *gas tank *ignition lock and keys *trunk lock and keys *battery *air cleaner assembly *tail light housings and bezels *new in the box rocker panels Clear title signed and notarized from previous owner in hand. (North Carolina title) Please let me know if you have any questions, thanks.
