1952 chevy sedan
Discussion in 'The Hokey Ass Message Board' started by mopar362000, Oct 15, 2013.
  1. mopar362000
    mopar362000
    216 6 with pg worn out.Have 55 235 with 3sp.Will the 216 auto flywheel work on 235.Where are the 216 passenger car mounts located on engine.My 235 pu mounts are on the side by the front cover.What should i look for to mount the later 235.Thanks Jimmie King
  2. wood470
    wood470
    I thought the powerglide models were 235s
  3. 'Mo
    'Mo
  4. downlojoe33
    downlojoe33
    I think starting in '53 the glides were 235's. look at the w ay the valve covers mount. Center bolts-216- perimeter bolts only-235.
  5. R Pope
    R Pope
    All PG cars had 235 engines, and some stick cars too. My '52 3speed is a 235 dipper. The valve covers have two bolts till '55. A 235 has the short side tin plate that ends at the head surface, the 216 cover goes up around the plugs.
