Projects 1951 Shoebox Custom project with lots of pics
Discussion in 'The Hokey Ass Message Board' started by EBW, Nov 10, 2011.
  1. EBW
    EBW
    After spending hours upon hours reading up and asking questions here on The HAMB, I pulled the trigger and purchased this Shoebox I had been watching.
    This is my first American project, so I am excited to say the least of jumping into this full force.
    My plan is to see if I can get the driveline working..IE: Motor to fire up, trans working, and brakes all around.... hoping I can drive her around a bit before a total tear down. At this point I am thinking no.. but it won't hurt to try.
    I am hoping a few of the Shoebox owners will chime in on this and help me along the way. I have a ton of questions and am searching this site as well as the others to find the answers, but haven't found all of them yet.... I have already purchased TWO "Green Bibles" and waiting for them to arrive.
    Here are some pictures after I picked her up.
  2. Royalshifter
    Royalshifter
    Moderator
    I have a rechromed grill assembly for sale if you are interested? Nice project by the way.
  3. kiwiandy
    kiwiandy
    Looks like a good starter. Complete and reasonably solid.
    Andy.
  4. TheLogLady
    TheLogLady
    Nifty ! Great core to start with..im tuned in !:)
  5. flatheadpete
    flatheadpete
    from Burton, MI
    Wow! Great shape! I have a couple headlight assemblies....pm me.
    My wife's '50 has Aerostar springs up front. 3" blocks on a Maverick rear. 302/C4. Almost on the road. They are great cars. Congrats!!
  6. resqd37Zep
    resqd37Zep
    from Nor Cal
    What a cool car. Good luck on your build.
  7. Matthew
    Matthew
    from Burien, WA
  8. rodknocker
    rodknocker
  9. 51custom
    51custom
    Hey, cool project...Been looking for one of those 4 blade fans ..LOL!
  10. EBW
    EBW
    Thanks, may take you up on that.
    I am curious on your setup with the Maverick rear. I think I have all the headlight assemblies, but I will PM if not.
    Funny.. that is the thread that got me here to the HAMB... I have read that many times.. Gave me ideas of what I want to do with the build.
  11. EBW
    EBW
    Thanks for all the comments !! I am reading and doing my homework, but still have a few questions that I am unclear on.
    Disk brakes... If I read correctly, I CAN NOT run disks with dropped spindles... Can someone confirm and the reasoning ??
    The infamous latch system.. I will take mine apart and see if I can clean it up and make work properly, but I really don't want my doors popping open while I drive. I know the 51 design is better than the 49, but I still value a proper closing system. If I use "bear claw" type latches, Can I still use the OG door handles? I think I read you can't and I need "poppers" to open the door.
    Now for my build idea. I am going the same route most are. I have been inspired by all the builds. Plans are DISK brakes up front, Aerostar springs, dropped spindels ( if possible ) 3-4" blocks in back, 4" chop, fender skirts, and white walls. I plan on using all the glass as I will be taking my family to events and cruising around. The BOSS is patient, but doesn't like the "wind blown" effect while driving... :rolleyes:
    With that, does the slanted B pillar mod make it more difficult for the glass ?? Or is it the same amount of work for the glass cutter to cut as the straight B pillar ? I think I answered my question, but wanted to hear from you all.
    The only difference from the other builds is the color I am thinking of using. Not 100% confirmed, but it is different from the traditional Black. A few builds here gave me the idea.
    I am waiting on the Green bibles to show up so I can start the build. I am so new to these, I couldn't even figure out what gear I was in... Never driven a column shifter !! I just slowly moved the shifter up and down, left to right until the car was able to move... :eek:
  12. Finnrodder
    Finnrodder
    from Finland
    I think that was a score,looks like solid to me.But is possible that there are few surprises,its a 60 yrs old car...
    I've understand that the disc brake kits wont work with the dropped uprights because of the caliper brackets.I havent find a suitable kit yet,but i'll be watching if someone recommends one or just a brackets.
    Good luck with your project!
  13. Looks like a very decent start for sure. There is a ton of shoebox builds going on here and mine is just one. Mines on a tight budget but maybe you want to check it out anyway on the you tube link.
  14. EBW
    EBW
    Thanks Finnrodder and Tedley, I am subscribed to every build on this site that I have found. Watching all of yours is what pushed me to get this one !!!
    I am waiting to clean up some clutter in the garage, and then I will start pulling things apart. I already know I will be doing some Floor repair. Not sure HOW much yet, the Rockers "seem" to be ok from what I have looked at .. more to follow !
  15. rodknocker
    rodknocker
  16. chop32
    chop32
    Ive run Fatman dropped uprights and front disc brakes my '49 since 2000 with no problems.
    Not sure of the brake kits manufacturer, they were with the extra parts I got with the car when I bought it in 1998, but there were no instructions or packaging.
    I havent found a kit that uses GM "metric" calipers and Volvo rotors (9" I think) like mine.
    I did find an ECI kit that used the same style brackets, but used larger Ford rotors...maybe mine is an earlier version?
    Hope this helps.
  17. Royalshifter
    Royalshifter
    Moderator
    My 51 has fatman dropped uprights and their disc kit. Stops on a dime.
  18. EBW
    EBW
    Thanks for the info... back to researching I go.
    Royalshifter ... PM sent
  19. modeltford
    modeltford
    Looks like a good project - shouild be a fun build!
    Also check-out shoeboxford.com LOTS of shoebox knowledge there too!
    Rich
  20. Looks like fun, keep us updated. Can't wait until the build starts!
  21. Stefan T
    Stefan T
    from Sweden
    Good luck with your shoebox
    nice project
  22. Buddy Palumbo
    Buddy Palumbo
    Yea , good luck with your project ... I'll be watching .
  23. EBW
    EBW
    Thanks for all the replies !! Waiting on parts as we speak.
  24. bbbronc
    bbbronc
    Was this car from the sacramento craigslist ad? If so I had been eyeballing it for a while. Had to resist. Only have time for one. Great looking ride and looking forward to seeing your progress
  25. carlos
    carlos
    from ohio
    hard to beat a shoebox when done right,good luck
  26. nagramos
    nagramos
    Good luck on your project. Spent a week last month working on mine, it's a pleasure when things finally happens.
  27. EBW
    EBW
    It may have been. I was "watching" it on another site he had it on for over a year.. He mentioned he had it listed in a few geographical Craigslist ads.
    UPDATE.. parts are starting to arrive.. Should have some progress pics shortly.
  28. shoebox50
    shoebox50
  29. bbbronc
    bbbronc
    I first saw the car back in march before I found mine. price was a little too high then. It reappeared recently for much less. Great looking car. Much better than the cl pics. Keep us posted. I can't wait to see your progress. Good luck
  30. EBW
    EBW
    Yes, he lowered his price, and of course there were 2 other guys coming to look at it the same weekend. Worked a deal and was done.
    Hoping to start making some headway soon.. Gathering parts and CLEANING the shop to make room...
