Hi Guys, We are in the middle of a 51 merc build, we did 4 wheel disc brake conversion we purchased from Jamco suspension in the states. The issue we're having now is the factory rear wheels wont clear the calipers, the concave of the rim rubs against the caliper and we're having a hard time trying to find a wheel that will fit and also allow us to have the rear over fender installed. We have tried using wheel spacers for the stock 15x6 wheels but it would require at least a 2-2.5" spacer. Just wondering what everyone else has done for wheel options?? If you guys have any advise in regards to this conversion??
Last time I did this I think that the solution for an OEM style wheel was a first-generation F-150 pickup wheel, circa 1977-ish. Those can be had at 15" x 6". They are available as reproductions for under $100USD/ea., or used.
Removed my discs and reinstalled the drums. But 73ish up f100 wheels were designed to clear “outer actuated brakes”
Thats crossed our mind a couple times lol- but we've spent so much time routing the brake lines and the mounts for the park brake cable. we're too far into it to go back now LOL
If you mean Torque Thrust style wheels, the "D" version has a cutout in the back of the spokes for caliper clearance.
Those are the ones! Could you show me a link, everything on their website is showing me an 83mm bore size, I need an 87mm
No link. Torque Thrust D wheels are vintage wheels. They have a slightly different spoke than the original Torque Thrust wheels. The modern Torque Thrust wheels fit discs, but they even yet still differ in appearance from the first two that I mentioned. Also, I am not sure that they have a 15" x 6". I am pretty sure that they start at 15" x 7".
One option is keep the wheel centers (so you can use the original hub caps) but swap out the wheel hoops. Ford pickup/van wheels in the late 60's-70's had hoops made to clear the disk brake caliper, on earlier disk brake wheels the center was riveted to the hoop, later disk brake wheels were welded. On the wheels I have the hoops are 5-1/2 to 6" wide. (Hoop hole is 12-5/8" across)
take time to find steel wheels that you can mount full size hubcaps on - or, steel chrome wheels - mags don't enhance the look of a Merc
