[GALLERY=][/GALLERY]1951 Ford Tudor sedan. 3rd owner car. Purchased in 2003 from the second owner who owned it since the 70’s. Car has always been garage kept. Absolutely zero rust!! 65k all original miles on the flathead 6 and has a three on the tree column shift. Engine runs good but could use a tune up. Stock exhaust with cherry bomb muffler. Still runs on the 6volt systems. All running gear is original to the car. Brakes were gone through a few years ago and work ok. Water pump was just rebuilt by a local shop. Battery was also recently replaced with a new 8volt one. Front has been lowered with new shocks and the back has blocks on the original leaf springs. All custom work done by Royal Kustoms in WA over the coarse of 10plus years and is as follows. All emblems, trim and handles have been shaved. Hood has been peaked. Front has a Mercury style opening with a ‘53 Kaiser floating bar. Headlights are frenched and are 50s Ford pickup. Taillights are new and have been frenched in. License plate has been frenched in to the decklid and opens from the passenger rear inside panel. Driprails have been shaved also. Car has about a 3 or so chop in the front with about 5 inch in the back. The lines on the chop are just perfect. No weird flat spots. All the garnish moldings have been fitted also. Has original Cadillac 1947 sombrero hubcaps on the front and Ford beauty rings on the back with fender skirts. Wide white wall tires all around with new inner tubes. Interior still has the original dealer installed plastic covers on the seats. Comes with original door panels in ok condition. All interior accessories will come with the car also. Here are some of the things that still need to be done. Side glass needs to be cut and installed. Some body work will need attention before paint. Stainless window trim needs to be cut and fitted. Comes with a clean 1951 Ford title,some of the original manuals and a fitted car cover. Please feel free to ask any questions you may have. Car is located in Portland, OR.
