1951 Ford Truck Project Pics
Discussion in 'The Hokey Ass Message Board' started by Scott in Missouri, Dec 29, 2008.
  1. Scott in Missouri
    Scott in Missouri
    from Missouri
    PM Sent~
    I have not had any problem, but you can never go wrong with a beefier set up. The transmission/motor are held in place fine with this mount. If you want more flex/tourqe bracing, I would consider a permanent cross member above the drive shaft if you have room. Aslo, I would say you should consider welding/bolting this in BEFORE you cut the old one to keep everything square.
    Scott
  2. JoshECS
    JoshECS
    I just bought a '48 F-1 on an unmolested '51 chassis and drivetrain. Scott, you've done all of the work that I think I want to do with ym '48 to use it as a daily shop truck.
    I appreciate you taking the time to do such a detailed write up, very very helpful.
    Ultimately, how does the Flattie on a T5 drive around town and occasionally on the highway? Is it perfectly adequate, or do you sometimes feel concerned that you are an obstacle that others struggle to avoid in traffic?
  3. Scott in Missouri
    Scott in Missouri
    from Missouri
    I used to think it was the best improvement I made to the truck...until I converted to 12 volts. I still think it is the best improvement for "drivability". It shifts like butter and now you get the 5th gear which is Over Drive and can hit the highway at 60 MPH.
    Scott
  4. motorgod7
    motorgod7
    from chico,ca.
    Fantastic thread, I have a 59 f100 that will be getting the same name on the doors.
  5. Bugsiegel
    Bugsiegel
    from New Jersey
  6. Black Knight 1
    Black Knight 1
    Great thread. I got a lot of inpiration for my 55 build.
  7. Kiwi 4d
    Kiwi 4d
    we found a similar problem with 10" pressure plate weights on a different brand adapter and wondered if cutting these weights off was an acceptable solution. I presume they may add pressure to the clutch plate as revs and momentum builds up. Looks like its worked for you.
  8. Tinpanharry
    Tinpanharry
    So did you sell the truck?
    Thanks!
    TPH
  9. Scott in Missouri
    Scott in Missouri
    from Missouri
    Yes I did sell it. It arrived in California last week.
    Scott
  10. Schoenmaker
    Schoenmaker
    from Holland
    Scott, thanks for the detailed descriptions, they will be my aid overseas in Holland!
  11. Sprout
    Sprout
  12. bobo1
    bobo1
    from France
    nice work on your truck ;)
