Auctions
1951 ford truck hotrod
Discussion in 'Cars For Sale' started by 52 ford coe, Apr 14, 2018.
  1. City: Vernon
    State: New York
    Price: 30000
    Completely built from ground up
    2x4 hand build frame. Jig built
    Cab is a 51' ford F1 pick up truck. The entire bottom foot, firewall, and floor is custom made
    Front suspension is original early ford I beam and wishbone. Wishbone has been split and frame mounted
    Original ford fluid filled friction shocks dampen the leaf spring suspension
    Four piston wilwood brakes on front end. All new original brakes on dually rear. Wilwood master cylinder
    Hand made rear swing arm suspension with coil over shocks
    Dana 70rear end 4.56 ratio. Milled aluminum housing cover
    All new steel wheels. One piece
    All new military non directional tred tires
    Custom fuel cell build from two GI cans pushed with electric fuel pump
    All lighting is n.o.s. Military converted to 12 volt. Blackout lights still work
    Battery box is converted military ammo can
    Windows covers,air cleaner cover and interior finished with military OD green canvas
    New steel radiator with customized Massey Harris tractor grill with hand made copper insert
    Air cleaner is 1954 Mercury oil bath converted to hold paper element
    Visor and copper accents are hand built from .052 pure solid copper with brass rivets to secure
    Ford 302 small block. Complete rebuild. Stock bore. Thumper cam. Holley 4 barrel carb. Aluminum Offey valve covers. Mallory ignition.
    Ford C4 trans completely rebuilt with shift kit and custom servo.
    Open header. Heat wrapped
    Stuart warner gauge set
    Custom covered pleated seats
    Shaved door handles
    Custom OD green weathered paint on body
    Pinstriped by some of the best guys at the Syracuse nationals
    Full documentation and pictures to go along with build
    Every piece of frame and suspension is hand made. Hundreds of hours of fabricating. Definitely will draw crowd.
    Picked as top 12 at Syracuse nationals
    Picked as old school round up winner at Syracuse nationals
    Featured spread in old school rodz magazine
    There are no weak points on this truck. Built right and attention to detail is everywhere you look. If you paid the have this built it would be double or triple this price
    Registered as 51' Ford F1
    Feel free to PM me and we can go from there. Thanks
    I would consider trades. Heavy equipment, tractor, other hot rods, telehandler, anything interesting
    Military. Rat rod. Hot rod. Custom build.
    Rick28 likes this.
