Hey guys, I put a rebuilt first gen small block 327 in my 1951 Chevy Styleline. Holley 600cfm. Any help on the easiest/best gas pedal,throttle linkage would be much appreciated. Thinking old Camaro? Thanks in advance.
If you aren't into fabrication, get something from Lokar. Otherwise, look for a throttle cable setup from a Chevy G van. Those things are sooo long that you can shorten them to fit anything. If you are running a TH400, look for a pedal with a kickdown switch.
What was said above is correct. Go to the local pic-a-part and pull a cable set up off of about any GM vehicle with a carb on it. It might take a bit of looking as they are getting hard to find, even there. If you know somebody with a stash of stuff in the back field you might even get it for free.
I have used pedal , cable setup from a Chev S10, S10 Blazer on several cars. Are / plentiful in the scrap yard , have a nice flat plastic mount on the dash. Sent from my iPad using H.A.M.B.
