1950 Ford Custom Four door Rear wheel drive Mechanical: 3.9 Liter 239 cid Flathead V8 3 speed manual transmission (3 on the tree) 6 Volt system Starts and runs well. It is able to be driven New master cylinder from Shoebox Central. Brakes need adjustment although the car does stop Portions of brake line have been replaced Carburetor has been rebuilt. Manual choke New fuel pump. New fuel filter New spark plugs. New spark plug wires New voltage regulator Fresh oil change Good exhaust Tires have less than 100 miles Horn works All outside lights work Interior: All glass is present. No cracks in windshield or rear window. Small crack in passenger front-side window Two-piece windshield Dashboard lights work Speedometer and odometer work 1 out of 2 dome lights work. Bulb may be out on one of them Interior is in good shape for almost 70 years old. Front seat has no rips or tears. No cracks in guage glass. Decent carpet and rubber flooring. The rear seat has original covering which has a rip so a new blanket was placed over the seat. No headliner. Door panels are original but definitely showing wear All windows and doors work Glove box interior is in good shape Exterior: Original patina. As far as I can tell the car has never been re-painted. Original black paint on inside of truck lid and door jams There is no structural rust on frame (surface rust). No rust through of floor boards (they are solid) Very rear portion of trunk floor has rust through. Underside of rocker panels are rusted (tops are solid where the door kick plates are). Driver's side rear fender with rust through. Rust through under right headlight None of the rust is affecting the structural integrity of the car Dent on panel just in front of drivers side door Original chrome on both bumpers is peeling All of the chrome trim, although not completely on the car will come with the car Original hood ornament No door sag or misalignment Exterior lights are not faded or dry-rotted Very neat piece of automotive history Simple car to work on Can be driven to car shows as is and would be a neat display Colorado Title Car is located in Cheyenne, Wyoming $2900 OBO
