1950 Chevy quarter window quandry
Discussion in 'The Hokey Ass Message Board' started by thetwistedpiston, Feb 3, 2013.
  1. thetwistedpiston
    thetwistedpiston
    I have a 1950 Chevy Styleline Deluxe that has (had) the sliding quarter windows. I would like to change to the fixed windows. I have glass that came from a car with fixed windows and would like to know if all I have to do is buy the rubber for the fixed windows or is this swap even possible.
    If push comes to shove I'm sure I can fab up some sort of mount and make it work. I was hoping for an easy swap.
    ...any insight would be appreciated.
    ¬ĽKeith
  2. dorf
    dorf
    from ohio
    is it the cpe in your avitar, if it is my olds is a cpe with fixed quarter glass and all it has is the rubber and the garnish molding holds it in . should be the same window .
  3. thetwistedpiston
    thetwistedpiston
    Yes, same as in the avatar. I was looking at Chevy of the 40's and they show a couple different fixed window rubber, I'll have to take a look and see if I can figure out what the difference is. Perhaps the size of the glass. Thanks for the reply, I guess I can order the rubber and see how it goes.
  4. 1953girlracer
    1953girlracer
    from Redlands
    Any good glass guy will have the rubber moulding for you to buy
  5. GREASER815
    GREASER815
    Got any more pictures of that rig? I like it!
  6. 325w
    325w
    Not sure if will help you are not. The tri 5 Chevy utility sedans that had the fixed 1/4 glass just had a couple of clips that were held with a screw. Then the garnish molding held the glass.
  7. thetwistedpiston
    thetwistedpiston
    Thanks I"ll look into that.
