1950 chevy cant keep it running
Discussion in 'The Hokey Ass Message Board' started by JasonSeaver, Oct 10, 2010.
  1. JasonSeaver
    JasonSeaver
    from detroit
    I changed the oil, put a new battery in and she started up after a few cranks. Drove to the end of the drive way sat for a minute and it stalled out. Since then it only turns over when the choke is all the way out and then only for a few seconds. Help would be much appreciated.It has a newer fuel pump and a gas jugg in the trunk. thanks
  2. chevyshack
    chevyshack
    Has it sat for a long time? Could be bad gas or a timing issue.
  3. JasonSeaver
    JasonSeaver
    from detroit
    not long at all, new gas in it before i started it. the timing may be the issue. do i check it with the timing light?
  4. big creep
    big creep
    check the fuel filter too, if it has one?
  5. JasonSeaver
    JasonSeaver
    from detroit
    bypassed it still had the problem
  6. chevyshack
    chevyshack
    Maybe its your carb. Could be gunked up and due for a cleaning. Maybe some crap in a jet.
  7. 52HardTop
    52HardTop
    It's starving for fuel. Might be something in the carb that's blocking fuel delivery? Dirt is always the culprit.
  8. Rickybop
    Rickybop
    from Michigan
  9. hotrodlolita
    hotrodlolita
    i feel your pain !!
  10. bandit1950
    bandit1950
    from Santa rosa
    Need more info. 6v or 12v. 216/235 or small block. Single carb, pionts, what do you have. Is there a balast conected to the coil or no. Could be a bad coil. You got a trouble light and multi meter? Fill in the blanks and an answer will be easier.
  11. SLAMIT
    SLAMIT
    I say Clean the Carb!!!!!! and put on a good fuel filter or two!!!
  12. SLAMIT
    SLAMIT
    Oh and get a real gas tank. I am sure it is on your priority list though. I have "Gotten cars running" that way before to and it usually causes issues.
  13. JasonSeaver
    JasonSeaver
    from detroit
    I took the carb off and cleaned it, it started up and i adjusted the throttle and choke so it idoled nice. I had it running for 5 min turned it off and when i tryed to turn it over again the starter just clicked. I enjoyed a very brief moment before the car took it away. Any tips on getting a starter working let me know Thanks
