1950 Chevrolet 3100 Body Work – Hood stripped & Louvered by Paul Harper, Roslyn, Wa. Otherwise, Body has been buffed from its original condition. The tailgate and the grill are the only replaced pieces on the truck…everything else is original. I purchased the truck primarily because of the great condition of the sheet metal. The truck spent most of its life as a farm truck in Eastern Washington (Sunnyside,Wa.) I have owned the truck for the last 20 years and it has been garaged during that time. Lower cab corners have some very small pinhole rust spots that you’d have to get down on the ground to see and that’s it for rust on the truck. Holes from the removal of the farm truck mirrors have not been filled. Truck was painted one time way back (maybe 60’s) Currently a light blue lacquer paint….was originally dark blue. The paint buffs out to a high sheen. About the motor – The original 216 splash-oiler was removed and replaced by a 1959 235 full oil pressured block. The block was hot tanked & completely rebuilt in Yakima, Washington by Richard at Joe's Grinding Machine Shop. Egge pistons and rods were used. It has an E-2 Howards cam (High Lift Cam), stainless valves, and cleaned up the exhaust and intake ports. Howards dual valve springs were used. The motor was balanced. A lot of time and research were used to make sure the best parts were used for both reliability and performance. It starts with ease and runs flawlessly. The motor was awarded “Best Motor” at the first show I took it to. Wiring – EZ Wiring (Professionally wired by Get Wired, Wenatchee, Wa) Wiring diagram provided to hang on your shop wall. Electronic Gauges – Classic Instruments $1,000 installed 2018. All gauges work as they should. Seat – Seat was reupholstered in Black Vinyl to fit the look of the truck by TrimCraft (Snohomish, Wa) Rear End – 8” Ford 3.90 Gears (the truck can idle along at car shows without clutching it and it can cruise down the freeway at 70MPH. The truck shifts with ease. Truck currently has 3” lowering blocks with stock leaf spring suspension. Front End – Stage 2 Fat Man Ford Mustang II IFS (+1 coil removed) work by John Preston (Cle Elum, Wa) Tail Lights – Blue Dot glass lenses Brakes – Front Disc, Rear Drum / Dual Master cylinder …Work done by Easy Street Hot Rods, Wenatchee, Wa. All new stainless brake lines are throughout the truck. The truck stops on a dime and straight (doesn’t veer one way or the other) Camshaft – Howards (high lift for that nice rumble) Lifters – Solid Pistons – Egge Electronic Ignition – Mallory Coil – Mallory Exhaust – Custom Dual Exhaust with Smithy’s…installed by Easy Street Hot Rods, Wenatchee, Wa. megaphones tail pipes were welded on. Custom Drive Shaft – New and made specific for the truck Headers – Fenton Headers …Jet Hot Coated Dual Carburetors – Dual Carter Weber w/elect. Chokes Air Cleaner – Polished aluminum finned air cleaner cover from Obrien Truckers Manifold – Offenhauser...Dual intake manifold - with custom Phenolic plates to eliminate any heat transfer to the fuel Wheels – 15” Chrome wheels from Wheel Vintiques. Direct fit wheels with Chrome Spiders Tires – Coker Classic 6.7-15 front, L78-15 Rear. Wide White bias ply for that period correct look Oil Filter – Remote polished aluminum finned Moon Equipped Valve Cover & Side Cover – Polished aluminum Offenhauser Transmission – Tremec -5 speed Transmission out of S-10 Fuel & Oil Lines – Black Braided Russell Fuel Lines, Moon Equipped Fuel Block Emergency Brake – Lokar Industries Heater – New heater core and every piece on the heater was stripped and powder coated Radiator – New Stereo - New vintage stereo with aux cable (made to look original) Engine compartment stripped, and repainted, inner fender wells and radiator support powder coated black Electric fan – New Electric Windshield Wiper Motor -installed and replace the vacuum controlled wipers Bed wood = new pine …painted flat black to match the look of the truck. 25,000 obo. 425-770-2441. Not interested in trades -Mike
