We finally changed out the rear leaf springs to 2 1/2 wide springs. It took sometime to put the right combination together.We made the leaf spring front hangers. We used Aerostar front coils with one coil cut to get the wheel well gap right. It also brought the camber into spec. We have a 1949 Plymouth owners manual and copied the ride height front the picture on the cover.
next is door hinge bushings and king pins and shocks. we are putting 2000 ford explorer front disc brakes and calipers on with custom mounting brackets. we are in idaho.
@msgt tank Nice car. Perhaps it is the camera angle, but the rear wheel appears too far forward in the wheel opening. If so, a new hole drilled in the spring pad for the spring bolt, like is done on early Chevys, could correct that fairly easily. I am a long time ‘49 Plymouth fan and have had a few. My current one is a Deluxe Club Coupe/ aka Two Door Sedan and have had since early 1995. Ray
