1949 Mercury accelerator linkage swap
Discussion in 'The Hokey Ass Message Board' started by Barriosrick, May 19, 2020.
  1. Barriosrick
    Barriosrick
    I’m asking for help or suggestions on my accelerator linkage. I recently replaced my intake manifold and carburetor to a 4 barrel Edelbrock 500cfm. The original accelerator linkage is set up for the passengers side and the Edelbrock Carburetor is set up for the drivers side. Any suggestions or is there a kit available for the switchover? Thank you
  2. You need to ask this on the main discussion forum instead of the intro section so more folks will see it.:).................Don.
  3. Mike51Merc
    Mike51Merc
    You could mount the carburetor backwards.
    Pist-n-Broke likes this.
  4. Barriosrick
    Barriosrick
    Thanks Don. I’m a new guy, just learnin!
    lothiandon1940 likes this.
  5. And that might sound sill to some but it works and has been done a lot over the years.
  6. Mike51Merc
    Mike51Merc
    Except reverse now becomes drive.....but you can cure that by flipping your differential:rolleyes:
  7. .....It's all good.
  8. el Scotto
    el Scotto
    from Tracy, CA
    I welded the little ball arm off a junk Holley 94 to one of the removable carb brackets on the Carter AFB in my '48 Mercury. Was able to use the original stock accelerator stuff.
  9. el Scotto
    el Scotto
    from Tracy, CA
    I have a better picture somewhere but you can see it in this one, just squint a bit...
  10. el Scotto
    el Scotto
    from Tracy, CA
    I found the picture of it!! Sorry for the terrible quality.
    I didn’t want to put some cheese-dick Speedway pedal in the car so I modified stuff to work.
    I have driven the car with this set up and there are zero problems. Works just like old Henry wanted a Carter AFB equipped small block in his heap!
  11. jimmy six
    jimmy six
    Back in the day it seemed that every swap of a SBC or a carb where there was crazy monkey motion linkage installed a 55-57 Chevrolet V8 firewall linkage. I used it a bunch. They were cheap in junk yards. And with one hole for the lever and 2 for 1/4” bolts or sheet metal screws( I never used them).
  12. BJR
    BJR
    Or you could just weld an arm on the stock cross firewall linkage in line with the carb linkage on the drivers side.
    Hnstray likes this.
  13. Barriosrick
    Barriosrick
  14. Barriosrick
    Barriosrick
    Thanks El Scotty. So you put this linkage on the passengers side?
  15. If you look close at the chain laying on the motor and at the link right at the throttle shaft the ball looks like it's laying on the chain link.
  16. el Scotto
    el Scotto
    from Tracy, CA
    I went and took more pictures. Little bracket I welded the ball arm onto screws onto the primary throttle shaft. Stock throttle arm had to be bent over a hair to clear the distributor if I remember correctly.
    41E63D0D-8FC4-4815-9CCB-64FE379B702C.jpeg 31ABC8CD-B7DB-4220-93EC-2175DEFB33A6.jpeg
  17. Length of arms at both ends has a lot to do with Pedal response.
    Hnstray likes this.
  18. Barriosrick
    Barriosrick
    Thank you. I am learning that as I try to fabricate the linkage.
  19. Barriosrick
    Barriosrick
    Thanks for all your help. And the pics
  20. If I were doing that job and had the O.E. carb on hand I'd try to make the one I build be the same length from throttle shaft to ball end. Then the movement under my Foot would be the same as it was in stock form with new unit.
  21. Barriosrick
    Barriosrick
    Excellent suggestion. Thanks
  22. Some Guy
    Some Guy
    I cut and shortened the original linkage and moved the mount. Been that way for a long time. 703126C0-D4C4-4007-BB69-C7693DA3312B.jpeg
  23. oldsman41
    oldsman41
    You can put a spoon pedal in with the cable or you can shorten yours and reweld
