Posting for a friend............ 1949 Chevrolet pickup BODY: Chopped 1 ½ “ Tops of both doors need to be done Inner cab panel needs to be cut Custom bead rolled floor and firewall Urethane Body Mounts Custom-made 6 ft bed Smooth running boards, fitted to front and rear fenders Custom tail light panels Custom-made tailgate Rolled rear pan Frenched headlight rings-not installed 2 hoods Grille Lower splash apron bumper CHASSIS: Scotts Hot Rods Independent Front Suspension w/coil overs Scotts 5-link rear suspension w/coil overs Frame shortened 4” 10-bolt rear end New front rotors and calipers Partially boxed frame Power brake booster-master and pedal Dropout trans mount Rack & Pinion Motor and trans mounted ENGINE: Low mileage (57,000) LS motor 4.8 out of a Tahoe, included computer Harness-gas pedal (drive by wire) Alt. A.C Compressor-Starter Exhaust manifolds-catalytic converters TRANS: 4L60 Automatic, low mileage (60,000) out of a 2wd truck Includes torque converter. $13,500 obo
