I have a couple questions, and I figured I'd ask them all at once. I need a radiator for mine, and I'm having a hard time finding one. What years will interchange? I took mine to get repaired, and I'm not even gonna post how much they wanted! Also, is there a spring that attaches to the brake pedal for it to return? If so, where might I find one? Thanks
Yeah, it's odd. The pedal is hard, stops the car fine, but the pedal remains down. The pressure stays in the line, the lights are still lit, if I pull it back with my toe it returns.
Gerg, thanks for the link. The radiators they sell are street rod stuff, I'm looking more towards something more original. I assume that 49-54 radiators will fit, are those the only years? How about trucks?
there is a return spring on the brake petal, i just checked one of my frames. i have an extra spring if you want it
Running this one in mine, nice piece for the price, upper hose outlet is a bit small, I may have it replaced with a larger one (fine for 6cyl., I'm running a 350)
...I've run these a couple times, they do have a small upper hose outlet but I've run em with V8's with no problems.
I have a recored 1949 Rad that I will not be using in my car.. if your interested we could work out a deal... it is just sitting here.
