Projects 1949 Buick Sedanette Mild Custom Build
Discussion in 'Traditional Customs' started by rockable, Mar 16, 2019.
  1. rockable
    rockable
    I just asked for it. My store has one guy who handles walk in customers. Give them a try!
    JalopyJimbo, loudbang and Sporty45 like this.
  2. Kevin Ardinger
    Kevin Ardinger
    I don’t see anything about the pvc board. What thickness did you use?
    Thanks
  3. rockable
    rockable
    Post #352.
    Sporty45 and loudbang like this.
  4. rockable
    rockable
    1223211126_HDR.jpg 1223211127_HDR.jpg 1223211127a_HDR.jpg 1223211127b_HDR.jpg 1223211127c_HDR.jpg Installing glass is hard and messy work. Especially, when youre doing it yourself. The back glass is all that's left and I'm missing one of the trim clips for the molding. Haven't decided if I am going to install it anyways.
  5. j hansen
    j hansen
    I can only see the reflection from the perfect paint job!!
    rockable, Thor1 and loudbang like this.
  6. BJR
    BJR
    Are you able to put the windshield trim on after the glass and gasket is installed in the car? I didn't think that was possible.
    loudbang and Thor1 like this.
  7. rockable
    rockable
    The moldings can only go on after everything else is installed. You DO have to install the clips on the pinch weld before you install the gasket and glass. Also, Steele recommends a glazing compound that is extremely messy. Hopefully it I sealed up tight! I'm missing one of those pinch weld clips. You don't happen to have one, do you?
    Also, my buddy talked me into gluing the quarter glass in with urethane. This eliminates leaks and rattles. And since I have AC, I'm never going to roll them down anyway.
    Thor1, chryslerfan55 and loudbang like this.
  8. BJR
    BJR
    I guess I am not remembering how I put my windshields in correctly. I thought I had to put the trim in the gasket first. I can look for the clips, I remember robbing my parts car for those clips, and I may have some left over. As I remember some of them were very rusty and not useable. Due to the holidays I may not be going to my farm where my shop is until the week end after New Years. I can look then. Merry Christmas.
    Thor1, loudbang and rockable like this.
  9. rockable
    rockable
    Thanks for looking. I found a guy near to me that has a 49 convertible and is collecting parts for a Sedanette. He is out of the country until after New Year's. It's possible he may have one, so I'm covering my bases.
  10. Rockable, might try these guys for those clips as they have bailed me out at times. Worth a shot.
    Restoration Specialties, 148 Minnow Creek Road, PO Box 328, Windbar, PA. 15963
    814-467-9842 Jeff or Bill
  11. Fat47
    Fat47
    Rock,
    I agree with BJR. The trim piece on the WS goes on before you put the WS in. I'm not sure about the rear window. I found the trim clips in an old wrecking yard. Couldn't find anyone currently making them. They were used on other years in the early 50's so you might look at other early Buicks.
  12. rockable
    rockable
    I do business with Jeff on every car. They have a lot of stuff but they won't have this. I will try French Lake if my early source doesn't have them. Thanks.
  13. rockable
    rockable
    In reading the body shop manual, it says to remove the trim piece first, then the lockstrip, glass, etc. Installation is the reverse. The trim covers the locking strip, I believe. You couldn't put the locking strip in with the trim in place.
    I guess I will find out. I'd rather take 2 beatings than remove that windshield, for sure. You do, for sure, have to put the clips on the pinch weld first and put sealant around them. Wish me luck!
    Merry Christmas!
  14. rockable
    rockable
    1224211419_HDR.jpg 1224211139_HDR.jpg Well, that was fun. Can't wait to do the next side. Rubber mallet works better than the heel of my hand.....which is bruised.
    JalopyJimbo, mgtstumpy, Thor1 and 8 others like this.
  15. rockable and loudbang like this.
  16. rockable
    rockable
    All the glass is in. If you ever do one of these, put the rear glass in before putting the deck lid on. Had a suction cup let go while trying to put the glass in place by myself and got 3 scuffs in the paint. Hopefully, it will buff out. Really pissed at myself but I will get over it.
  17. Wow, what a looker it will be, Rock!
  18. BIG milestone there! Bet you are glad that is behind you. Bummer about the rear deck...
  19. rockable
    rockable
    I bought a set of Sombreros off ebay a couple of years ago and decided it was time to see if this was going to work. This is a slickly designed package that includes a pedestal, a custom machined bolt through retainer with a strong magnet on top of it and the medallions are modified with a steel base. So, the center just snaps in place. I dont know who made these but they did a great job.
    I'm going to try to adapt 56 Buick centers to it. We'll see if that works out.
  20. BJR
    BJR
    Or put a set of 49 Cad rear fenders on and call it good. They bolt right on .
    Rand Man and Thor1 like this.
  21. rockable
    rockable
    That ain't happening. Car is painted and, besides, I like the Buick fenders better. You put the Caddy fenders on yours. :p
  22. BJR
    BJR
    If you used the Caddy fenders you wouldn't have to change the wheel cover logos.:D:p
  23. rockable
    rockable
    Just stuck up there with some tape. I will have to make some bezels. Still, it will be easier and cheaper than putting Caddy rear quarters on it. ;) 1231211501.jpg
  24. rockable
    rockable
    Bezel prototype no. 2. I'm not going to tell you what I said when the dremel tool slipped and put that scar in the face of it. I was less than 2 minutes from being done with it.
    I cut out the stock, hammerformed the bezel, then cut the center out with a nibbler. Finished it up with dremel and tools.
    54delray, Hnstray, mgtstumpy and 9 others like this.
  25. southerncad
    southerncad
    Admittedly, I haven't read all 13 pages of this post, but I did see where you mentioned that you have AC installed...am curious as to what heat&air unit you used? Am getting ready to do the same to my '49 Cad, and figure that your room under the dash is about as crowded as it is on my car. So what's the "easy fix"?
  26. rockable
    rockable
    I have a VintageAir Super in mine. You need to go back and look at my firewall work and compare it to yours, however. I had plenty of room once I reduced the firewall recess for the straight 8. I could probably have squeezed it in anyway. Since the Caddy had a V8, your firewall should be different.
  27. BJR
    BJR
    In my 49 Buick I used a Gen II ComPac - Heat Cool and Defrost. Fit and works great.
  28. rockable
    rockable
    0219221359_HDR.jpg Getting some more jewelry installed.
    JalopyJimbo, brEad, BJR and 12 others like this.
  29. Rand Man
    Rand Man
    I like your Buick. Nice wheel covers.
    JalopyJimbo, Hnstray, Thor1 and 2 others like this.
  30. rockable
    rockable
    Making progress. I got the front end mostly assembled today. With a little luck, I may get the entire front end done this week.....assuming I can round up qualified help.
    JalopyJimbo, brEad, EBW and 10 others like this.
