https://www.facebook.com/video.php?v=3247081538731525 1948 Chevy Stylemaster 2 door sedan project. This car was built in the late 80's with that era of streetrod style. The car had been sitting for awhile before I got it. Its has a great running 1968 327 4 barrel Q-jet with and powerglide trans. The engine has had a minor tune up, oil change, wires and new distributor. The trans has new fluid and shits great. There is a GM column with the shifter on the column. The suspension is all from an AMC Pacer. Power rack works but leaks little. The rear is a dana 35 with highway gears. I'd guess 2 something ratio. It has power brakes new lines on the front and a few new one on the back. The brakes work well. Both the rear main brake line and fuel line had been changed before so I didn't mess with them. Just blew them out. It has a new 65 mustang gas tank mounted in the trunk. Charging system works but the lights will need to be wired. Does have a new trans cooler and electric radiator fan. The stock radiator has some small leaks. I did get it out last weekend and drive it around. It drove like a car that been sitting but not bad. Some of the cons on the car is the side window glass need replaced. The interior is pretty bare. Most of the body work and patching was done backyard. Filter and crude patches. I do have bumpers and a grill In my opinion this car sits somewhere between basket case project and ready to drive. And is why it priced at $5000 obo. I do have a good PA title in my name.
Worked on it some last weekend. Added more pictures. Also the Transmission is a turbo 350 not a power glide
