1948 Chevrolet 3100 5 window 1/2 ton short bed. Engine is a 1958 283 sbc with 2 barrel Rochester carb. Runs strong, doesnt smokr. Carb needs adjustment, wont idle for long. Transsmison is stock, 4 speed on the floor, same as rear axle. New 3 inch lowered leaf springs up front. E-Z wiring kit is almost finishedn just needs to be hooked up to the rebuilt guages & headlight switch. Brakes just needs two flex hoses to be installed & bled to be done. Brand new 1 wire alternator installed same time E-Z wiring kit was being installed. I do jave a bunch of new items, as well as some used items in good condtion that goes with truck. I have a good used gas tank from a 1948 fleetline to be mounted up under bed, due to original gas tank being bad. With a good weekend worth of work, truck can be a driver. I also have the trucks title!! $6,500 obo
Installed brand new rochester 2 barrel carb, runs flawless! Truck is almost daily driver status! Send me a PM if interested
