1948 Chev truck question
Discussion in 'The Hokey Ass Message Board' started by Henderson55, Mar 24, 2012.
  1. Henderson55
    Henderson55
    from Canada
    Does anyone know outthere if the cab and front fenders on a 48 Chev
    1 1/2 ton grain truck are the same as the cab and front fenders on a 1/2 ton pick up? I have found my fathers first grain truck he purchased new in 1948 and wouldlike to take the cab and front end and transplant on to a s-10 frame. I just am not sure if the sheet metal is the same as the half ton?
    thanks
  2. jtbloye
    jtbloye
    HI the fenders from 1 1/2 are not the same im working on 1948 chev 1/2 ton and was going to buy a set but was told the wheel well are to big if you need more info you are from canada right call bills truck shop he can give you all the info you need
  3. LB+1
    LB+1
    from 71291
    Cab will fit 1/2 ton
  4. Henderson55
    Henderson55
    from Canada
    Thanks , do you have a contact for Bills Truck Shop??
  5. jtbloye
    jtbloye
    contact for bills truck shop Bill 1-905-725-3460 fax 905-725-2022 email:bill@billstruckshop
    www.billstruckshop.com
  6. 40Standard
    40Standard
    from Indy
    cab will work but not the fenders & hood
  7. OldoginMd
    OldoginMd
    Actually the fenders / hood will work but you will have a BIG opening for the wheel well .. I have seen these fenders on lowered truck with big crome wheeels and tires ... ugly in my opine
  8. cw1949
    cw1949
    The fenders are wider also.
  9. front fenders on one ton and smaller are the same as 1/2 tons.
  10. Henderson55
    Henderson55
    from Canada
  11. Henderson55
    Henderson55
    from Canada
