1947 Mercury Lowering
Discussion in 'The Hokey Ass Message Board' started by jamcoupe, Feb 12, 2014.
  1. jamcoupe
    jamcoupe
  2. Mudslinger
    Mudslinger
    Oops I posted for a car.
  3. jamcoupe
    jamcoupe
    Mudsliger this is for a car.
  4. Cougar98
    Cougar98
    from Ankeny, IA
    I just got done putting one in my 47' Ford. Not the easiest install, but doable. I'll post pics as soon as I can. From what I've been getting is it's not a true 3" drop, it's more of a 1.5" drop. On mine, the holes didn't line up and the spring pad area had to be opened about 3/8". If I was you, I would look at the spring set up, ie: pulling a leaf or two, and a drop axle from Sid. Just my $.02
  5. Olderchild
    Olderchild
    from Ohio
    Why not a Sid's 4'' drop axle ???
  6. jamcoupe
    jamcoupe
    Sids Looks like they way to go. Thanks
  7. ochamsrasor
    ochamsrasor
    I have done this crossmember swap twice I believe the results are with the price and effort. They advise you that it will not work with a flat motor.
  8. jamcoupe
    jamcoupe
    How much did it lower the car?
  9. Cougar98
    Cougar98
    from Ankeny, IA
    With the crossmember and a 4" drop axle, I only saw a 5 1/2" drop. I decided to pull half of the springs out. It sits 10" to the bottom of the bumper. With 235/60/15's up front
  10. Cougar98
    Cougar98
    from Ankeny, IA
    ImageUploadedByH.A.M.B.1403995977.567330.jpg ImageUploadedByH.A.M.B.1403996030.798779.jpg
