Technical 1947 Ford PU, Outside Door Handle Removal
Discussion in 'The Hokey Ass Message Board' started by 48FordFanatic, Jan 18, 2015.
  1. 48FordFanatic
    48FordFanatic
    from Maine
    Trying to remove the outside door handle of a 1947 Ford PU. Everything is loose, I've got the bottom of the door removed for patch panels and I can see the handle move in and out about 1/2 inch in the latch mechanism but it won't come out . It seems like the square shaft of the handle should slide right out of the latch once the handle is unbolted from the door . Any help would be greatly appreciated. John
  2. oldrelics
    oldrelics
    from Calgary
    Yes it should slide out, but sometimes that square shaft gets twisted when the mechanisms seize up and somebody reefs on the handles to try and open the doors. Shine a flashlight down from the glass crack and might be able to see if that's what's goin on.
  3. 48FordFanatic
    48FordFanatic
    from Maine
    Oldrelics you were right . The square shaft was twisted. I hated to do it but I had to cut off the handle then cut the square shaft again from inside the door with a hacksaw. Thanks.
  4. porknbeaner
    porknbeaner
    Sometimes especially on a truck that has seen its share of back roads that get a build up of crap on the shaft as well as getting twisted. You may have to give the end of the shaft a good cleaning.
