Here is a truck with potential. Comes with a clear title, not easy to find these days it seems. Box is pretty nice, missing a tailgate. Front clip is actually pretty good also, the couple of dents there would work out fine. the driver's side running board is maybe patch pieces. The cab is probably patch pieces unless you can see other options. I stabbed in a 48 truck rearend, stronger than the banjo but might not match your plans. I have lots of 46-47 parts, if you want something not shown in this truck, let me know, I probably have it. I have front brake parts if you want to stick with the drum brakes. this will roll, easily loaded. Let me know what you think.
I would separate the parts if folks wanted, box/front clip/frame. If that interests you, send me a message...
