Technical 1947 Fleetline Heater
Discussion in 'The Hokey Ass Message Board' started by bobsundance, Dec 18, 2019.
  1. bobsundance
    bobsundance
    I have a 47 Fleetline that has the round Harrison heater, the core is cracked and all the ones i look up are for earlier years or say they only fit trucks of my year. I would just hate to spend the money for a new heater core that does not fit. Anyone have any experience with this?
  2. goldmountain
    goldmountain
    Could you provide a picture?
  3. Hellfish
    Hellfish
    Take it to a local radiator repair shop. They can replace the core
  4. goldmountain
    goldmountain
    Not if it has a round core. They are made of unobtanium.
    Sent from my SM-T350 using The H.A.M.B. mobile app
  5. harpo1313
    harpo1313
    from wareham,ma
    But repairable.
    belair likes this.
  6. I have a slightly older round Harrison heater but it has a square core inside that is fitted to a round mounting plate. Note the corners of the tanks are rounded off.
  7. bobsundance
    bobsundance
  8. goldmountain
    goldmountain
    Put a rubber plug on one connection. Make a test plug out of heater hose and a fitting for the other connection and pressurized it to about 10 psi and test for leaks. Solder the leaks and you should be good.
  9. miker98038
    miker98038
