1947 Chevy 3100 with a Cab mounted gas tank?
Discussion in 'The Hokey Ass Message Board' started by forty9_slownlow, Feb 21, 2011.
  1. forty9_slownlow
    forty9_slownlow
    from mia fl
    hi guys,
    looking at a '47 recently and the everything checks out except that it has the gas tank behind the seat. I thought all '47s came with it under the bed?
    am i wrong or missing something?
    thanks
    in advance
  2. jcmarz
    jcmarz
    from Chino, Ca
    You are right. 47s and 48s had the gas tank under the bed with the filling tube sticking out of the apron thats between the bed and running board. The cab you are looking at is not 47.
  3. ...someone could've put a tank there, is the truck stock?...is the shift on the floor,...what's the vin no. prefix letters?,...47's should have "ER" in the vin.
  4. forty9_slownlow
    forty9_slownlow
    from mia fl
    got the vin at work. punched it into the vin decoder on stovebolt and it spat out exactly what i got. '47 chevy 3100. the floor shifter is on the floor. i havent seen the truck only a pic as im out of state, but the side pic i got doesnt show it on the bed. its kinda at a funny angle.
  5. jcmarz
    jcmarz
    from Chino, Ca
    Maybe they just put the gas tank behind the seat like Rusty-uno said.
  6. jetnow1
    jetnow1
    from CT
    1. A-D Truckers
    I do not think anyone would move the tank intp the cab- look at all the
    posts on moving them out- seems more likely someone switched the
    serial number plate onto a later cab to get into pre 48 shows before the
    dates changed at NSRA etc. Jim
  7. DE SOTO
    DE SOTO
    Does the cab have a Vent on the Side of the Cowl ?
    Early cabs had a Side vent, I think '47-'48 only ... Later ones Didnt.
  8. side vents on 50 and older...
  9. TagMan
    TagMan
    I recall reading that the '41-'46 Chevy truck was carried over to the first couple of months of '47 production (late '46?) and were titled as '47's. It was sometimes called the '47 "First Design". Anybody able to verify that? How about a pic of your '47?
  10. very early 47's looked like 46's, but the gas tank was under the seat.
    ...and I've had a couple 47-8's that someone put tanks in behind the seat, probly cuz those under-frame tanks got beat up by farmers drivin thru the feilds and pastures and behind-seat tanks were easier to find.
    Pics when you get em,...thanks
  11. slysball
    slysball
    1947 used a floor shift. with no parking brake on left floor.
    1948 used a column shift, with parking brake in left floor
    1949 gas tank behind the seat.
  12. forty9_slownlow
    forty9_slownlow
    from mia fl
  13. ...thanks for the pic, is that chrome trim on the fenders? ..that things dolled up ain't it?
  14. forty9_slownlow
    forty9_slownlow
    from mia fl
    yeah, but its not all original.
  15. Curt B
    Curt B
    To elaborate on what he said take a close look at the dash just above the steering column. 48 cabs don't have a reverse bulge which provides clearance for the column shifter that all other years have.
  16. 47 and 48 Chevs/GMC's had a smoother firewall like this,
    49 and newer Chevs/GMC's had an extra ribs stamped in the firewall (look below the master cyl),...there's another set behind the battery.
    these are both trucks I put together, oddly both were red from the factory, most were green.
    I've messed with these trucks for almost 40 years and I still keep learnin stuff.
  17. Ghostrider
    Ghostrider
    A friend of mine just picked up a '48 that someone added the in cab tank behind the seat. The truck still had the frame mounted tank as well.
  18. Chevy built essentially the same truck '47-'54 with minor changes. Not all changes coincided with a model year change. These trucks are now 60 years old, and most have been repaired and kept going with junkyard parts pulled from several different year models. Many trucks out there that have been pieced together with parts from a half dozen different trucks of different model years. Don't be surprised at anything you find.
  19. forty9_slownlow
    forty9_slownlow
    from mia fl
    ^^very good point.
