I have a set of front and rear backing plates and drums from a 1946 Ford 1/2 ton truck chassis. Im going to use them on my '30 coupe. Im looking to replace the Wheel cylinders with new ones. Can anyone tell me what make, model, and year of vehicle will work? For example a 1976 Ford bronco. Posted using the Full Custom H.A.M.B. App!
there are later model cylinders that fit. they are available at most of the aftermarket parts stores. post on ford barn, I am sure that somebody on that sight will have the info you need.
Duhhh why not purchase the correct wheel cylinders for the brakes, they are easily available from any antique parts supplier and do the job the way they were intended to rather than some cob job mismatch stuff.
1939-1948 Left rear wheel cylinder CarQuest/EIS # EW156002 1939-1948 Right rear wheel cylinder CarQuest/EIS # EW156003 1942-1948 Left front wheel cylinder CarQuest/EIS # EW156000 1942-1948 Right front wheel cylinder CarQuest/EIS # EW156001 1939-1941 Front wheel cylinder repair kit CarQuest/EIS # C552 1942-1948 Front wheel cylinder repair kit CarQuest/EIS # C568 1939-1948 Rear wheel cylinder repair kit CarQuest/EIS # C554 1939-1948 Front brake hose CarQuest/EIS # SP296 1939-1948 New brake master cylinder CarQuest/EIS # E1050 1939-1948 Brake master cylinder repair kit CarQuest/EIS # M16 1939-1942 Front and rear brake shoes Raybestos # 38PG(premium quality) or 38RP(Standard quality) 1946-1948 Front and rear brake shoes Raybestos # 37PG(premium quality) or 37RP(standard quality)
