1946 ford tudor sedan build
Discussion in 'The Hokey Ass Message Board' started by CHOPPED '46, Jan 15, 2011.
  1. Looking good Jurgen, you've made some nice progress
    Groeten Hennie
  2. Looking really good mate, good to see someone building a car with wrecking yard parts not out of a catalogue .
  3. janbuick
    janbuick
    looks good jurgen
    keep posting pic's
  4. 48FordFanatic
    48FordFanatic
    from Maine
    Nice build thread. Keep up the good work.
  5. sololobo
    sololobo
    J man, I am very impressed with this build. I love these fat fender fFords. I had a 42 and a 46 and had a great time with both. I wasn't brave enough to chop either of mine. You and your handsome young son look perfect in the car, enjoy my friend. Thanx for sharing your build with us. ~sololobo~
  6. Tim
    Tim
    from KCMO
    maybe im looking at this wrong, but are those motor mounts bolted to your heads? that seems like asking for trouble. just thinking about the stress on the head bolts, the torque staying correct, blowing threw head gaskets and having to prop up the motor to pull a head seeing as the head is holding the motor up?
    i might be missing something but id rather have had said something then have you have some head bolts fail and have your bottom end laying on the ground under the car.
  7. 1955merc
    1955merc
    from TN
    I was wondering what year and model Mercedes you used for the brake setup? I'm doing a '46 and you are making it soooo much easier. Thanks. John
  8. hi John
    the setup came from a mercedes W124 300 diesel.
    but every mercedes setup from these years will work.
    Jurgen
  9. ss34coupe
    ss34coupe
    I like what you are doing here - a nice mix of parts to build the chassis. You have a neat project!
  10. kooscoe
    kooscoe
    Cool Build here in the Netherlands:D:D
    Did you get any furder with it?
    Have fun Building.
  11. farmer12
    farmer12
    Looking forward some more pics! Great build so far!
  12. more pic's in a while.
    my rack and pignon (jaguar) is rebuild 'cause it was leaking oil
    the plans are changed.
    the shop of the guy who should help me with the chop is destoid in a fire including his car.so it's gone take a while before he can help me.
    so I made some changes to the engine and keep on going with some bodywork and stuff.
    the evenings are always to short for me.
  13. Roothawg
    Roothawg
    Great build. Keep up the good work.
  14. kooscoe
    kooscoe
    Yes very sorrowful that he hade A fire in his shop. Lukely he still got lots of energie to rebuild the shop and Suburban.
    Did you do the rebuild of the steering rack yourshelf? My rack is leaking also.
    Have fun Building. Diedelson
  15. leaking of the jaguar steeringrack is very common.
    I didn't rebuild it by myself. It's a very tricky job.
  16. yesterday a friend of my and I made a fast photoshop to get some inspiration.
    don't mind the mirrors and the decall on the door is just a example.
    modifications:
    some serious lowering
    3.5inch chop
    slanted doorposts
    one piece window
    lengted the front fenders a bit on the front
    wide white wall's
    what do you guys think ?
      377.7 KB
  17. Mr Blue
    Mr Blue
    from Florida
    Looks good!
    I saw the light blue car that you used for your photo shop example and the chop looks great in person. Good luck! Don
  18. if you have more pictures of that car,will you please send them to me ?
    I still want to know how they did the chop.
  19. Mr Blue
    Mr Blue
    from Florida
    I only have one other picture than the one you have. If I find any more I will pass them on:)
  20. Hdonlybob
    Hdonlybob
    Very nice work. I am envious of your talents...
    And that little guy in the picture will just love that first ride you give him too...
    Good luck, and good for you.
    Cheers.........
  21. ford5t1
    ford5t1
    from usa
    hey jurgen, nice work. was the headgasket blown? saw the car in person and it's awesome! keep up the good work, see you next time... by the way if everything goes as it should be i will get my jag ifs and irs at the end of this year. so we will talk again..
    see ya
    twan
  22. Mr Blue: thanks for the compliments and the picture.
    Hdonlybob and roothawg: thanks for the compliments.
    twan: the engine runs very good right now,I milled the heads 1mm and rebuild them.
    are you going for a jag IRS under your pickup ? what about the airride ?
  23. ford5t1
    ford5t1
    from usa
    hey jurgen, yes a jag set up it is and i'm not sure if i build it on airride or do a static and go to the dmv (rdw) and then install the airride..
    see ya
    twan
  24. Mr Blue
    Mr Blue
    from Florida
    Jurgen,
    Heres another chopped sedan I found on the HAMB. Did not know if you saw it or not. Don
  25. hey Don
    thanks,but I allready found that one.
    I'm searching for a year now on the net for chopped tudor's and found a lot of them.
    a lot of them don't look right to me when chopped. some of them (like the blue one) look awsome.
  26. 1955merc
    1955merc
    from TN
    What switch did you use with the wipers? John
  27. this was the damage :(
    a dent in the roof.
    a dent in the panel behind the drivers door.
    and a dent in the rear fender.
  28. I did some bodywork and after that it looks like this.
    I'm doing the final bodywork after the chop.
