Projects 1946 buick sedanette with top chop
Discussion in 'Traditional Customs' started by Lines, Jul 4, 2018.
  1. Lines
    Lines
    from Germany
    This was an Idea I hade, not right for a traditional custom but something different. The bezels are from a1950 studebaker.
  2. 'Mo
    'Mo
    Traditionally, part of customizing has always been to create something unique. I think your headlight idea fits this criteria perfectly.
  3. Dick Stevens
    Dick Stevens
    Exactly, customizing is not like hot rodding where everyone wanted to follow what the latest cool thing was done. Customizers all wanted to create something different from what anyone else had done while using some of the same basic ideas, such as shaving trimwork and frenching headlights, tailights and antennas.
    'Mo likes this.
  4. 'Mo
    'Mo
    '51 Buick Sombreros are the koolest, but too deep for most wheels.
    EDIT: 1952 (thanks, BuckeyeBuicks. ;))
  5. Lines
    Lines
    from Germany
    I have 15" rims with 8,20 mounted at the moment, originaly they came with 14" rims I think they are 5,5" wide.
  6. 'Mo
    'Mo
    The Buick Sombreros require a much deeper center. :(
    (I believe '51 wheels were 6 1/2", with a big off-set.)
    EDIT: 6" (Thanks, rudestude. ;))
  7. rudestude
    rudestude
    Look on the Custom Chronicles site ...the forum on mounting 47 Cadillac Sombreros on non Cadillac rims...look to be the same as the Buicks.....
    Sent from my QTASUN1 using The H.A.M.B. mobile app
  8. 'Mo
    'Mo
    The Buick actually has a deeper dish than the Caddie, as may be seen below.
    Buick...
    Caddie...
    I think the Buick Sombrero might have become the 'Go-to" custom wheel cover, had it not been for the fact that Buick wheels were the deepest and widest of the era. (In fact, Buick rims were commonly used on Ford and Chevy centers for those deep reversed rims of the fifties.)
    rudestude likes this.
  9. rudestude
    rudestude
    Ya I have had them on some of my Buicks and other cars through the years mine actually had the valve stem still in the original location which when reversed put it on the back side of the rim... I still have a pair of 56 Buick wagon back rims with reversed centers or rims ,which ever you prefer, wagon rims being wider than the standard car rim....also in the Hollander I was just looking at lists 42/54 Buick whl. W/disk cover interchangeable with other Buicks and some Cadillacs if you remove the clips and also some Packard's
    42/54 15"-6"
    55-56 15"-6"
    55-58 50, 60, 70 series w/15"-6 1/2" whl.
    59-60
    All 5" on 5" center
    All above are Buicks
    It showing a 0.3" center drop difference on the Cad rims w/ full disks
    In the one article I read they removed the clips from the back of the Buick covers and attached them to some beauty rings then when snapped on the deepth worked out and they did really stock out from the rim... I have mounted Moon Disks that way before and it worked out OK.....plus the adhesives they have now days would work but it might be a problem if you need to remove them....you got me thinking I believe I may have some Olds , Pontiac , and maybe early Buick full covers still hanging around.... I'm gone...going digging...
    'Mo likes this.
  10. Lines
    Lines
    from Germany
    Cool. I will have to take some mesurements and look thruw my papers I colected. For the back rims I think the wheel house in the back was pretty narrow in 46 and 47 could even be ind 48 too. The wheelhouses in 49 where wider I read in an article. I think thats why the 15" came out in 49. But not fore shure. my 46 should of had 14" from factory.
  11. Orn
    Orn
    Nice Buick. All Buicks of the fourties had either 16” or 15” wheels. No one had 14” from factory.
    RDR and firstinsteele like this.
  12. Lines
    Lines
    from Germany
    Sorry youre right. Got mangeled up.
  13. Lines
    Lines
    from Germany
    Just looked up the file
    1946-1947
    Special 6.50x16
    Super 6.50x16
    Roadmaster 7.00x15
    1948-1949
    Special 6.50x16
    Super 7.60x15
    Roadmaster 8.20x15
    I dont know if this is correct tire size 7.00x15 is very small tire for a Roadmaster
    Orn likes this.
  14. rudestude
    rudestude
    'Mo likes this.
  15. Lines
    Lines
    from Germany
    Thank you.
    So the 46 Roadmaster had 7.00x15 tire size. That is a small tire for that huge car.
  16. BuckeyeBuicks
    BuckeyeBuicks
    from ohio
    Those are 1952 Buick wheel covers, not 51.
  17. 'Mo
    'Mo
    Thanks. I'll Edit the post.
  18. Damn Marcus, Going Strong! Good Work! Jeroen Told Me You wrote me and I didn't reply? Not My Style.. Think Maybe you came in my spam box? Anyway... Thats Why Im visitiing your built! Heads Up! Skip'
  19. Lines
    Lines
    from Germany
    Hi Skip,
    thanks its a lot to do more then expected but its comming on bit for bit.
    Surfcityrocker likes this.
  20. Yes ;-( I see that man! But.. (saidly) thats alsways the thing. Anyway, Cool To see and follow your progress! Thumbs Up!
  21. Lines
    Lines
    from Germany
    A small progress, took me ages to get this bit of metal to fit.
  22. Top Job.. Good work takes time! Do You work with pullmax or?
  23. BJR
    BJR
    That piece of metal fits great, you did a great job fitting that.
    Hnstray likes this.
  24. Lines
    Lines
    from Germany
    Thank you for the compliment.
    Skip@ I did the metal piece with hammer and dolly for the curve and got rounding with a strecher. The curve of the floor I did with the english wheel. The deepening was hammered in in three metall rectangular tubes wich I jammed in the vice to adjust the depth.
  25. Lines
    Lines
    from Germany
    Some more little progress but its comming together bit for bit.
    UNSHINED 2, rockable and Gasser 57 like this.
  26. just like taking a bath, go in dirty, & a little rough around the edges, come out clean & new, looking great again. Nice work.
  27. Lines
    Lines
    from Germany
    Not a big progress but getting on.
    I will change the mountig bolt hole that why its not welded.
    At the moment I'm fixing the door hinges there is a bit of movement in them and the door can be lined up. When everything is lined the next step will be to weld in the upper rocker panel.
    UNSHINED 2 likes this.
  28. Sweet & Low
    Sweet & Low
    Looks like a labor of love. Keep up the great work.
    Just curious, what size rod have you been using?
  29. Lines
    Lines
    from Germany
    Thanks Sweet and Low.
    Yes it is a labor of work.
    What do you mean with rod size?
  30. Lines
    Lines
    from Germany
    I weld the parts with Mig and with a 0.8mm weldingwire.
    I want to try TIG welding. seems less heat and easier to grind.
