1942 Jeep to Flathead Ford V8 Help !!!!
Discussion in 'The Hokey Ass Message Board' started by Limey Steve, Jan 3, 2011.
  1. Limey Steve
    Limey Steve
    Alliance Vendor
    from Whittier
    Hi I'm looking for an adapter to fit a Flathead V8 in a 1942 jeep does anyone know if the beast was made or not . I see Offy made one for a T-90 trans , the 42 is a Willys with a T-84 trans. Any help, info or a part to buy would be much appreciated.
    Cheers
  2. Jax2A
    Jax2A
    Look for a T90 as well... the T84 won't live long behind a flathead.
  3. Use a '46+ T90. Make life easy. The V8 will spill the guts out of the T48.
    The T90 Adapter was made by Offy and is Part #5825. If you can't find one, you could modify an Advance Adapters SBF/T90 kit, or make your own adapter if you're crafty.
    A friend put a 59AB Flathead V8 in his GPW, but used an S-10 T5 & Transfer Case, then just used custom driveshafts. He buzzes down the interstate at 70mph.
    Pic below was found on the net when I was researching putting a Flatty in my old CJ2A.
  4. Limey Steve
    Limey Steve
    Alliance Vendor
    from Whittier
    Thanks , that is some good advise , now we need a T90 trans too .
    I like the T5 idea too I'll put that to the owner .
