Guys i picked up a 1942 Chrysler Windsor 4dr. sedan and does anyone know the front and rear track width? I wanted to update front suspension and rearend then the drivetrain! thanks guys!
Standard Catalog of American Cars does not list that dimension for the '42 thru '48 models....much to my surprise. If you have the car in hand, why not just measure it? Ray
"The Classic Car Database" shows various tread widths for Chrysler products, but for whatever reason, '42 models aren't listed. If one could determine if there were no changes from '41 (or prior), that info may suffice. http://www.classiccardatabase.com/prewar-models/car-models-C.php#Chrysler
To update the suspension relocate the upper shock mounts, get a thicker front sway bar made up or find something similar that's thicker, put discs on the stub axles, new 2" lower front springs, 2" blocks on the rear with new shocks, also a rear sway bar........maybe join the P15-D24 Forum...............whilst the Chrysler is Not a Plymouth or Dodge the same basic chassis & suspension is used in all mopars from the late 30's thru to the late 40's and you really do NOT need to swap the front end to a Mustprang or similar to get it to handle and drive well.....but its your car.......I'd suggest checking out a few mopars before getting the hotaxe ready..............regards, Andyd
