Projects 1941 super Deluxe old school custom
Discussion in 'Traditional Customs' started by Larry Clare, Feb 12, 2018.
  1. s55mercury66
    s55mercury66
    from SW Wyoming
    They are wrapped to keep the lube in and dirt out. Nice old Ford, thanks for all the pics.
    Larry Clare likes this.
  2. LBCD
    LBCD
    Cool car Larry! Great to see more 41 Fords popping up here, and you are in CA.
  3. Larry Clare
    Larry Clare
    thanks for the tip I thought it was for noise ,had no clue .
  4. Larry Clare
    Larry Clare
    thanks , I like the wide body stance and narrow front . I think 41's are not recognized as much as 40's and 46's
  5. LBCD
    LBCD
    Absolutely!
    Check out this 4 door 41 Mercury...[​IMG]
    Same body and rear fenders....great family cruisers
    Larry Clare and lurker mick like this.
  6. Larry Clare
    Larry Clare
  7. Larry Clare
    Larry Clare
    That is cool , I don't know why 4 doors aren't more popular I don't like to get out of the car to let others in .
    LBCD likes this.
  8. Larry Clare
    Larry Clare
    thank you . my fingers are crossed
  9. I hope you're going to put those Evans heads back on.
    Here's your chrome dash. i just posted this pic in Hombre's Ruin's thread. It's from Custom Car Chronicle, 1951 Eastern Auto catalog...
  10. Larry Clare
    Larry Clare
    yeah those look like the panels but did anyone offer the dash and steering column in chrome also wondow surrounds ? I plan on having the evans heads and offenhauser 4 barrel intake back on after having them checked out .
  11. Larry Clare
    Larry Clare
    more to share on the 41 here are some pics and I learned a lot soo far converted Lincoln v-12 distributor .125 pistons . going to a tear down on the engine and do it right if it is still useable. 20180218_135928.jpg 20180218_140112.jpg 20180219_145847.jpg
    rodncustomdreams and 'Mo like this.
  12. 302GMC
    302GMC
    from Idaho
    Standard Automotive Products, the parent company of Fenton, made most of the Ford & Merc metal dress-up & replacements for plastic dash parts.
    rodncustomdreams and Larry Clare like this.
  13. 'Mo
    'Mo
    How amazing is that?
    It seems you have a real period treasure. Please keep us posted on your progress.
  14. Larry Clare
    Larry Clare
    rodncustomdreams likes this.
  15. Larry Clare
    Larry Clare
    Will do I have been taking it slow found out the crank Marked 1CM is a mercury 4" stroke going to start pulling pistons tomorrow.
  16. Larry Clare
    Larry Clare
    Having a hard time finding pictures of wrapped springs anyone have one to share ?
  17. Torchie
    Torchie
  18. 2bubbas
    2bubbas
    Have one of those wrapped springs out in the barn- came off my '46- try to remember to take a picture-
  19. 2bubbas
    2bubbas
    wrapped spring- notice grease fittings-
  20. Larry Clare
    Larry Clare
    Nice pic is a little dark but the snow makes good contrast . where are you located .
  21. Larry Clare
    Larry Clare
    update I tried CLR in # 1 cylinder it appeared as rust but when I went to scrub it it was almost plastic like substance the CLR and a plastic tuffie scrub pad got it loose and it looks like after soaking for an overnite i may actually get # 1 to move more than a little . will keep you posted .
  22. Larry Clare
    Larry Clare
  23. 'Mo
    'Mo
    Pistons stuck? Try Marvel Mystery Oil. Miracle stuff!
    (Automatic transmission fluid can also be added.)
  24. Larry Clare
    Larry Clare
    only one stuck #1 and tried marvel a few times on it not giving much also tried transmission fluid pb blaster wd 40 gel hot water, coke kinda helped this almost looks like plastic more than rust got almost all of it above piston now am soaking it again will try to move it again from the bottom thanks for the suggestion.
  25. 'Mo
    'Mo
    ATF and Acetone is great for stuck carbs. You might give that a try.
  26. Larry Clare
    Larry Clare
    I will try that what could it hurt thanks
