Technical 1941 Chevy Sedan - Brakes
Discussion in 'The Hokey Ass Message Board' started by Voh, Aug 15, 2021.
  1. Voh
    Voh
    So My ‘41 Chevy sedan is SBC swapped, using stock pedals with THD chassis engineering MC for a mustang master cylinder. Messing with bleeding the brakes this weekend and found the brake pedal hits the motor / bell housing after only about 2” of travel. Is there a way to solve this without a firewall mounted pedal/master cylinders? 2807B358-16CD-4E0A-B329-A98ED604F117.jpeg
  2. squirrel
    how far would you have to bend the arm to the left to make it clear the engine?
  3. Voh
    Voh
    not very far. But i wasn’t sure how to make the pedal work on the inside without moving the floor opening. There isn’t a lot of space to the column.
  4. Bob Lowry
    Bob Lowry
    I had the same problem back in 1965 on my '40 Chevy coupe. Back then, I got a huge crowbar
    and just pried the pedal over until it cleared the motor. Never had an issue with it. and drove it
    hard for 5yrs. after. Bob
  5. chubbie
    chubbie
    I cut mine and welded it to the side that was enough to clear
  6. Voh
    Voh
    What did you do with the piece through the floor? did you have to move the floor opening over?
  7. Voh
    Voh
    So I might be crazy, but something acts like it shifted since it was in last time. Here is a pic from a while back. I never recall the pedal hitting. Ugh!
  8. chubbie
    chubbie
    yes i'm sure i did move the hole/ seal down and out...that much
