1941 Buick with camaro front clip???
Discussion in 'The Hokey Ass Message Board' started by Hemi j, Jan 15, 2012.
  1. Hemi j
    Hemi j
    from Colorado
    Has anybody installed a camaro front
    clip on a 41 Buick sedanette and if
    so what generation camaro? Thanks guys
  2. I had redone driveshaft work on a '39 Buick coupe back in maybe 1995. That car had a narrowed 2nd gen Camaro front clip. It was narrowed 2" in the middle.
    That car had a driving characteristic that felt darting with any steering wheel movement. I'm not sure if the way it was done is wrong, or if the steering characteristics of that clip changed that much based on being narrowed.
    I had to drive the car to troubleshoot driveshaft vibrations and to make corrections. I did that.
  3. Had a guy in our car club with a 41 Buick special sedanette...used a 1st [rear steer] gen. camaro/nova subframe and it tucked in nicely, looked great and worked fine drum brake sub...he also ..er...used a ahem...302 ford engine/tranny in it..go figure.
  4. Hemi j
    Hemi j
    from Colorado
    Thanks, I know from past projects
    you can't narrow them. Thanks again
    for the warning!!
  5. Hemi j
    Hemi j
    from Colorado
    Thanks guys
  6. mitchsfab
    mitchsfab
    Installed a MII in a '41 with a 350/700 combo.. Worked terrific
  7. Hemi j
    Hemi j
    from Colorado
    That was my plan but I keep hearing
    bad things about MKll's, bad handling,
    a arm bending etc.
  8. mitchsfab
    mitchsfab
    I used a TCI '55 chevy pu kit. The track width was just right. I have not seen a-arm bend. How are are they driving the car, like an offroad car? Unless its a cheap kit or junk yard parts. The handling is all in the set up or how its installed.
  9. Hemi j
    Hemi j
    from Colorado
    I don't know, I just heard this stuff
    on the HAMB ?
  10. Hemi j
    Hemi j
    from Colorado
    I might be wrong isn't a mkll's a fatman
    unit ?
  11. mitchsfab
    mitchsfab
    That's why they don't handle and bend...Don't use fatman. You need to use better quality like TCI or Heidts.
  12. Hemi j
    Hemi j
    from Colorado
    Thanks !!!!!
  13. Hnstray
    Hnstray
    from Quincy, IL
    First off, there is no reason a Camaro clip, or most others, can't be narrowed successfully.
    You do have to narrow the cross member accurately and narrow the center link to retain the original geometry, and install it at the correct angle,but with that done it should drive just like it did in the original application. If it doesn't, one or more of the preceding was done poorly.
    As for MMII front ends, that has evolved into a generic term and all are not created equal. And, installation and alignment must accurate. In my experience, Fatman MMII is at least equal to, and usually better than, the competitive units I have either purchased or examined carefully. I have a Heidts unit that is satisfactory but the main crossmember is thinner than a Fatman unit which is 5/16 material.
    It seems to me that Fatman, like a lot of other highly successful businesses, become a target or "whipping boy" for people who resent others success. I have never seen any evidence of the alleged "inferiority".
    You are, of course, free to make any choice that suits you, but I would suggest you do more personal investigation than merely the hearsay you seem to accept without question.
    Ray
  14. leadhead51
    leadhead51
    from ontario
    i have put in several malibu and cuttlass front clips.all have been driving around for years.s 10 dropped spindles and coils fit if you want to go lower after it is in.i happen to be doing a 41 buick right now with a 84 cuttlass clip and a big block buick,hope this helps
  15. need louvers ?
    need louvers ?
    A properly set up Mustang II unit will work just fine. The bigest problems with Mustang II kits has stemmed from the lower arms since the "strut arm eliminator" type kits have become available. The problem is that most use an "A" type lower arm that the rear joint of which is supported by a tube through the crossmember and nothing else. The arms don't really bend, but the back of the unsupported crossmemeber "blows out" from braking force and extreme road jolt such as railroad tracks, pot holes, etc. This can be solved very easily by tying the rear pivots into the frame with a simple bracket or even better, two to place the joint in double shear. That way the jolts and road shock goes into the frame and not the back of the crossmember. I still prefer when possible to run stock style or tube struts that mimic stock geometery.
    I will not speak at any length about my distaste for Fatman stuff, it is not from any jealousy at his success as I am not in compitition with him in any way. He has a tendency to try to over build with heavier material rather than correct engineering IN MY OPINION. He seems to have no problem changing and comprimising key geometrical ellements of the Mustang II system to suit fitment needs, such as standing up springs and relocating pivot centers... Simple thought and engineering would solve most problems. That is all I will say, but I will add I see allot of the same issues in other manufacturers as well. I won't turn your thread into an argument about this.
    As much as I like the correctly engineered Mustang II system, and as much as I normally disdane frame "clips", if you brought your car to me for this, the first suspension I would look into would be a '78-'87 A or G body clip from any GM of the period. That would be the malibu, Monte Carlo, Chevelle, 'Camino, etc. This clip is right at 58 1/2" hub to hub, which should be right in the ballpark for your needs and has quite a bit better camber curve and roll center values than the earlier Nova/Camaro unit. Also still super common in wrecking yards and just driving down the street. It's also about three inches narrower than the lates and widest of the Nova/Camaro clips as well. Oh, and weight values are real close to correct too.
    Just my .06
    Just after I hit send on this I saw the post above... perfect timing!
  16. Hemi j
    Hemi j
    from Colorado
    Thanks guys, The main reason for
    this thread is to save money but
    without hurting the project.I have
    a sedanette that I have spent hours chopping
    4" which came out great. I have many
    more hours of metal work to finish
    the frenched head lights, tail lights and
    bumpers so since I'm 61 and retired
    I need to save as much money as I can
    if I ever want to get this thing finished.
    It also needs to be on air ride !!!
    Thanks again for all the help guys
  17. George/Maine
    George/Maine
    I saw a GM car maybe a 39 pontica those big fenders cars 37 chevy ect.When using a front steer 70s camaro clip make sure it isn,t going to stick out the front fender.It does happen.
  18. LOWLYDE
    LOWLYDE
    someone did a not so good job on mine,(before I bought it)They Cut the X member out and the trailing arms out too! I had to get another frame from a 41 buick
  19. desotot
    desotot
    I upholstered a 41 buick convertible coupe a couple of years ago, it was clipped with a first gen camaro, and about twenty years ago I did an olds coupe with a first gen camaro. The steering lines up nice.
