Projects 1940s Model A Sport Coupe Build Thread
Discussion in 'The Hokey Ass Message Board' started by mramc1, Nov 28, 2011.
  1. Ford Blue
    Ford Blue
    Very nice work, I hope my roadster fairs this well!
  2. coupster
    coupster
    from Oscoda Mi
    I have been watching your build since the first post, you have done a fantastic job! Congratulations, you should be very proud of what YOU have created!
  3. oakmckinley
    oakmckinley
    Nice build!
    Who cares what anybody thinks about your minivan seat. You're the one who is going be sitting on it, and I bet it's much more comfy than the original. ;)
    I put some chrysler 300 seats in my fairlane, and man what a difference from the lumpy original bench seat. Maybe 20 yrs ago I could've stood the old seat but my 39 yr old butt needs something better now.
  4. Rat.Racer
    Rat.Racer
    from Maryland
    Just starting out reading this thread and it's probably one of the best I've seen, definitely subscribing...
  5. Tnomoldw
    Tnomoldw
    :) Josh, it's getting better all the time. I like every thing you have done and when you get it trimmed out it will be superb. :cool::D
  6. Tnomoldw
    Tnomoldw
    :)I saw this dash panel. It looks simple to make. :cool::D
  7. mramc1
    mramc1
    Working on odds and ends before the body comes off for final paint and assembly work. I made a stock Model A emergency brake fit with a new mount.
    First I folded the rear ear over to bolt to the center crossmember.
    Then I twisted up a piece of flat stock that tied the crossmember to the front ear on the e-brake. Simple and effective.
    Then I notched the floor panel from the handle and Bam!, e-brake action.
    After testing some other components it was time to dissemble the body and get it off the frame. My dad was up over the weekend and helped me out.
    With the body off I can finish weld all the pieces that are just tacked and unfinished. When setting the tranny up I crudely notched the center crossmember to clear. Time to dress that up.
    And in the front.
    I plan on finishing, painting, and plumbing the chassis first. Then I'll get the body done and marry the two back up, hopefully by the end of spring.
  8. Rat.Racer
    Rat.Racer
    from Maryland
    I amazed by this thread every time I check it out. I love the wood floorboards, flea market find? Do you have any plans to stain them black or leave them natural?
  9. mramc1
    mramc1
    Yes, swap meet find. They are painted black now. The rear floor will also be wood, but I need to cut it out and paint it.
  10. mramc1
    mramc1
    Not too much visual progress lately. I have been working on trying to build a clutch Z-bar linkage. Ordered some parts for that, but still waiting for delivery. I tore the rear suspension all down for sandblasting and final welding.
    Also started to work on the engine. It's from a '83 Ford Ranger and I thought it was a 2.3L, but could be a 2.0L. Anyway, starting to clean the engine up and get it ready for paint. I think I'll just be running a Holley 2300 2 bbl for now as jets are cheap for easy dial in.
  11. 29ToyA
    29ToyA
    Sweet!
    Your doing great!
  12. mramc1
    mramc1
    I cleaned up my front wishbone mounts this weekend. At first I had just used straight up bolt on mounts on the outside of the frame. The more I looked at them the more I thought they needed some reworking.
    So I wanted to make the mounts mount to the bottom of the frame so first thing I did was cut off the portion that hung below the frame.
    Then I set it up 90 degrees to the original mount plate.
    Then this.
    Bam!
    Now the mount hides under the frame and looks much better.
    And the tires still clear too!
  13. wizard29oz
    wizard29oz
    from new york
    Looks 'Mo Better' ! Worth the time and nice fabrication.
  14. daddio211
    daddio211
    Excellent improvement and nice craftsmanship.
    Sent from my DROID device using the TJJ mobile app
  15. mramc1
    mramc1
    This weekend I built my clutch linkage. It's a Z-bar made out of 1/2" round stock. Heims make up the pivot points.
    The clutch pedal end in place with heim bolted through the pedal mount.
    I had to weld an ear onto the pedal mount to mount the other heim.
    The clutch fork for the T5 is pulled by a small cable and a pivot on the bell housing. I had a large yoke that fit perfect over the stock Mustang setup.
    I have to wait until the clutch and pressure plate are in before I can weld the tranny side arm in the correct location, but here is the linkage looks all mocked up.
    I also started on the front shock mounts. I'm using the factory from '36 spring mount as the lower and will cut down a set of F1 mounts for the uppers.
  16. mramc1
    mramc1
    Finished up the shock mounts. Pretty simple and should be strong.
    Bam.
    And that's it.
  17. What an amazing transformation through hard work and talent.
    Well done and thanks for sharing your build.
  18. Tnomoldw
    Tnomoldw
    :)All super nice Josh.....:D:cool:
  19. wizard29oz
    wizard29oz
    from new york
    :cool:Very nice work.
  20. mramc1
    mramc1
    Chassis naked.
    Bam!
    Devil with a black dress on.
    Jump up.
    Have mercy.
  21. thunderbirdesq
    thunderbirdesq
    Hell yea! Neat idea on those front shock mounts too. Hey thanks for the fair deal on the grille shell too bud!
  22. Mr.Musico
    Mr.Musico
    from SoCal
  23. I feel so lazy, man this thing is looking great and going fast. I am headed to the shop thanks for the updates and inspiration.
  24. Binger
    Binger
    from wyoming
    I love the shock mounts. Keep up the Great work.
  25. mramc1
    mramc1
    Thanks, Andy. I like the good stuff to go to the people who can appreciate and use it!
  26. kingpins
    kingpins
  27. lrapso
    lrapso
    from Costa Rica
    Good job, just go ahead....
  28. wizard29oz
    wizard29oz
    from new york
    :D Nice "A" closed cab, I particularly like the louvered visor....but then I'm biased some.............great progress on the build, your thread is one of my sources of inspiration to "git movin' ".
  29. rusty truck
    rusty truck
    from rochester
  30. mramc1
    mramc1
    Well, let's see...the stock market was up, but down today. Chance of thunder showers in the afternoon. My buddy just had his first kid. That's all the updates I can think of right now.
    Oh wait, you mean on my car? Hold on....
