Hot Rods 1940 wishbone ball spacer.
Discussion in 'The Hokey Ass Message Board' started by Departed, Jul 28, 2020.
  1. Departed
    Departed
    from Canada
    Hi guys,
    Thanks for all the help on my previous posts.
    I was wondering how I should go about to add more caster to my front wheels?
    Is there a spacer you can add to the wishbone ball joint like there is on a Model A ? I've never seen them for the 40...
    Otherwise I'd have to lie cut my wishbones to give me a bit of caster but I don't really want to do that........
    thanks guys!
    flatheadpete and lothiandon1940 like this.
  2. Damn, that is one sweet looking '40. I've seen people just fab up a simple bracket to bolt (or weld) to the frame and subsequently re-attach the wishbone ball to the bracket. You would need to determine just how deep the bracket would need to be to accomplish what you want. I know it might sound a bit hinky, but it works.
    Packrat and Departed like this.
  3. Marty Strode
    Marty Strode
    PM @saltracer 219, I think he has a spacer on his 40 sedan.
    Departed and lothiandon1940 like this.
  4. krylon32
    krylon32
    Alliance Vendor
    from Nebraska
    Chassis Engineering used to make a wishbone spacer, maybe there's one lurking on someones shelf.?
  5. lothiandon1940 likes this.
  6. alchemy
    alchemy
    How about you find another cap, flip it over, add some spacers to hold it a bit below the original face of the crossmember? Make the spacers the needed thickness to get your caster goal.
  7. fordor41
    fordor41
    try Heidts. they bought Chassis Engineering. They made a spacer.
  8. Years ago, I made one for a 46 with a piece 1/8 wall rectangular tubing and two stock caps. Cut a hole in the tubing and recessed one cap in it and welded it in.. Bolted that to the crossmember and put the cap on. Worked great!
