Technical 1940 Willys front Axle info
Discussion in 'Traditional Hot Rods' started by hotrod--willys, Dec 4, 2019 at 6:15 PM.
  1. hotrod--willys
    hotrod--willys
    I have a 1940 Willys front axle that is missing spindles' and shock mt's. Can anyone tell me what is front or back of this axle?? Can the axle be used either way?
  2. Axle has caster built in. With spring pads level, king pins lean backward.
  3. hotrod--willys
    hotrod--willys
    Yes. Now I can see the caster. Thank you.
