Technical 1940 plymouth coupe
Discussion in 'Traditional Customs' started by gasmonkeyrodder, Feb 18, 2020.
  1. gasmonkeyrodder
    gasmonkeyrodder
    from uk
    Hi Guys need some help? I am building a 1940 Plymouth coupe and I want to use cavalier rack & pinion steering. do they do a none powered rack rear steer? or are they all power racks? any help would be much appreciated.
    Regards
    Mark
  2. ol-nobull
    ol-nobull
    Hi & welcome. I like your profile page as it says a lot. You would do better with your question on the steering if you post it on the main forum (HAMB) as more will see it there. When you do post there show us some photo's of your rides. Jimmie
    40 Plymouth driver likes this.
  3. gasmonkeyrodder
    gasmonkeyrodder
    from uk
  4. lucas.gray39
    lucas.gray39
  5. gasmonkeyrodder
    gasmonkeyrodder
    from uk
    318 mopar pretty much stock for know.
  6. 4woody
    4woody
  7. paul philliup
    paul philliup
    from ohio
    I like your project I have a 39 Plymouth Coupe.
  8. Nice Mopar. Do you plan to run a six barrel setup on the 318?
    gasmonkeyrodder likes this.
  9. gatz
    gatz
    Looks like you've got 2 threads with the same title going on.
    This is what I posted in the other one.
    This company sells manual units for the GM cars;
    • 1982-1986 Buick Skyhawk
    • 1982-1986 Chevrolet Cavalier
    • 1982-1986 Oldsmobile Firenza
    • 1982-1983 Pontiac J2000
    • 1986 Pontiac Sunbird
    https://www.detroitaxle.com/shop/st...plete-manual-steering-rack-pinion-assembly-6/
    IDK if those cars actually came optioned as non-PS; might check Hollanders.
    If you're interested going with PS units, I have a complete '94 power Cavalier setup including pump. And a '98 Z24 (quicker ratio) setup as well.
    They were what I was going to use in my '40 Chrysler,
    but went with a Jag XJ6.
    Note, you can delete the other thread.
  10. gasmonkeyrodder
    gasmonkeyrodder
    from uk
    yes I was hoping to run the six barrel set up if I can get it to run good.
  11. gasmonkeyrodder
    gasmonkeyrodder
    from uk
    thank you, its all starting to come together now.
  12. Check on Pontiac Sunfire manual racks, my 48 Plymouth is set up with one. Chevy didn't offer manual steering but Pontiac did in the same platform.
  13. gasmonkeyrodder
    gasmonkeyrodder
    from uk
  14. gasmonkeyrodder
    gasmonkeyrodder
    from uk
  15. gasmonkeyrodder
    gasmonkeyrodder
    from uk
  16. gasmonkeyrodder
    gasmonkeyrodder
    from uk
    chryslerfan55 and scotty t like this.
  17. missysdad1
    missysdad1
    I suggest you retain the stock steering if you are keeping the front suspension. I ran a 318 in a '48 Plymouth for years and it was a very pleasant ride. Motor had to be offset to the passenger side and I used a Dodge 4x4 oil pan as I recall to make it all happy. When the motor went south I went with a fabbed front frame stub with Mustang components and later wished I had kept it the way it was. With dropped uprights, cut coils and re-located shock mounts it was plenty low and drove great. With the Mustang II stuff not so much. Great project. Good luck!
  18. andydodge
    andydodge
    I have had my 1940 Oz Dodge since 1971......318 Poly since 1973......you can swap in the 1941-1954 or 56 upper A arms which are a stronger setup, just use the 1940 onwards upper inner pin & bush on the 1941 onwards arm................I have had a 9" narrowed Austin 1800 rack & pinion since 1980, front end uses 1940 lower A arms, 1941-56 stub axles, Oz 11" vented discs, 1" thick sway bar of original shape, heim jointed links & relocated upper shock mounts........drives well........andyd
      207.1 KB
  19. Blue-Collar-HotRods
    Blue-Collar-HotRods
    Kudos on keeping it mopar powered! Two thumbs up!
  20. gasmonkeyrodder
    gasmonkeyrodder
    from uk
  21. gasmonkeyrodder
    gasmonkeyrodder
    from uk
    missysdad1 likes this.
  22. missysdad1
    missysdad1
    Relocating the shock mounts is the most important part of updating the front suspension on these old MoPars. There are kits and there are plans to make your own mounts widely available. Dropped uprights will also help by lowering the car considerably without compromising the ride or driveability. Good progress so far, keep up the good work.
