Projects 1940 NOS trans delima
Discussion in 'The Hokey Ass Message Board' started by stillrunners, Jul 12, 2020.
  1. Bought what was a fresh to build trannie at a swap meet. The restored car it was going in went to the dark side
    Any - suggestions on what to clean the rust off and save the parts the owner bought ? Here's the case - I'll take pictures of the gears later - they left it out in the rain I guess
    kidcampbell71 likes this.
  2. Great thread on citric acid
    molasses works but smells
    Sacrificial anode
    paint stripper
    sand blast or media blast
    Try throwing your old socks at it !
  3. Was thinking that after I posted. The original owner bought a lot of new parts that didn't get wet....but major ones did
  4. anthony myrick
    anthony myrick
    I have used molasses and CLR for removing rust from mechanical parts.
    The CLR was the fastest.
  5. I would replace the bearings just simply cost does not justify using rusty bearings. Unless I’m missing something and some of these bearings are worth a bunch.
    The rest of the parts defiantly look savable
  6. mlagusis
    mlagusis
    Vinegar works good too. Easier to get rid of than molasses.
  7. I've brought a gearbox case back from the dead in molasses, but I don't know that I would put gears in it, or any acid.
  8. Beanscoot
    Beanscoot
    I would scrub the inside of the case with soap and water and a stiff bristled brush. Dry and use.
    Any loose rust will come off, the superficial rust remaining will stay in place.
    And of course you can change the oil after a short while for extra insurance.
