1940 Ford deluxe four door sedan, original car with good history, dependable driver, clean interior, mostly original paint, all original interior, dash, factory Ford heater with correct heater switch, owners manual, 4 new tires, new brake master cylinder, wheel cylinders, rubber hoses with silicon fluid, new radiator, coil, distributor, voltage regulator, gas sending unit, fuel pump, wiper motor, front floor mat, fan belt, modern water pumps, gas tank cleaned and coated, generator and starter rebuilt, even compression on each cylinder, Optima 6 volt battery, solid floors, rust in rear tool box area, spare tire dip in trunk, and some on fenders as pictures will show, you can drive this car home, more pictures if interested, $11,900. 606-309-2420
