Technical 1940 ford coupe
Discussion in 'Traditional Hot Rods' started by johnold1938, Jan 21, 2014.
  1. johnold1938
    johnold1938
    from indiana
    what do you think is a good size tire package for a 1940 ford standard coupe traditional hotrod. humbly john!
  2. Jason455
    Jason455
    bias 560-15 front l78-15 rear
  3. geoford41
    geoford41
    from Delaware
    165-75 15 on 5" wide rims front (approx 25" tall) 235-75-15 on 6" or 7" rear (approx 29" tall) Not the WW ones on the avatar
  4. okiedokie
    okiedokie
    from Ok
    X2
  5. 19Fordy
    19Fordy
    The "look" will also depend on what changes you have made to the original suspension. With that said, click on photos below to obtain larger photos. The car shown below in the first photo also has a 4 in. dropped axle, a Posie reversed eye front spring and a stock rear end. The Posie spring lowers the car almost 1 1/2 in. The Magnum axles lowers the car another 2 inches. The smaller dia. front tires are 25.8 in. tall which also drops the car. It has:
    5:60 x 15 on the front with 15 x 5 1/2 early FORD truck rims.
    7:60 x 15 on the rear with 15 x 6 rims with 4 in. back space on the rear.
    The second photo is the same car years ago with the same front tires but with 1950 x 5 1/2 Merc wheels on the front and the stock axle. On the stock rear are 8:20x15 tires on 15 x 5 1/2 1950 Merc rims. Rear suspension is still stock.
    Take a look at some of the old Rod&Custom magazines from the 60,s, like the timeless classic - Bob McCoy 40 Ford sedan and tech info. shown here: http://hotrodsandjalopies.blogspot.com/2011/12/bob-mccoys-1940-ford-sedana-california.html Today, radial tires are also available for the stock 1940 16 in. wheels.
  6. i.rant
    i.rant
    from Illinois
    1. 1940 Ford
    Mine are 195 65 x15 on a 6" front and 235 75x15 on a 7" rear ImageUploadedByH.A.M.B.1403295104.499692.jpg
    Posted using the Full Custom H.A.M.B. App
  7. I'm running 165/80/15 on 15x5 and 235/70/15's on 15x7 American TTO's.
    Mr.Norton and lothiandon1940 like this.
  8. Mr.Norton
    Mr.Norton
    from Sweden
    Im running 185/75/14 on 14x6" at front, and 235/75/15 on 8x15 at rear, vintage american racings, Hank
  9. joel
    joel
    I have 195/65/15 on 5.5 in rims front and 235/70/15 on 7 in rims rear. I may change the fronts to 205/70/15 after I get the weight on the front ( engine ,trans, rad, etc. I don't have a dropped axle.
  10. 34toddster
    34toddster
    from Missouri
    X2
  11. Moriarity
    Moriarity
    SUPER MODERATOR
    ImageUploadedByH.A.M.B.1420582364.443340.jpg ImageUploadedByH.A.M.B.1420582419.091277.jpg
    Mine 5.60x15 up front and. 8.20x15 rear.
    UNCLECHET, Smart62, Mr.Norton and 2 others like this.
  12. Schwanke Engines
    Schwanke Engines
    All about the big N Littles. 7.50x16 in back 4.50x16 in fronts.
  13. Babar40
    Babar40
    from Florida
    image.jpg What Moriarity said.
    Moriarity likes this.
  14. birdman1
    birdman1
    I found out the hard way(of course) NOT to buy tires and wheels before the front is DONE. on my 1939 Ford coupe, I have a 4" dropped axle, reversed eye springs. I am also using aSpeedway Motors chevy disc brake kit. The bottom of my grill is 4" off the ground with the 175x55x15: tires and 2004 Mustang wheels. the Mustang wheels have a lot of backspace and a lot of offset. all I could fine that will fit. I am not done with the front tire situation yet, but it can be a problem if not thought out as I did.
      1.8 MB
  15. dirty old man
    dirty old man
    I'm just too damn old, I guess. To me a '40 coupe should be level, no rake, or a very slight tail droop. Cadillac sombreros, on the front at least, on the rear also if you have room after you install the teardrop skirts with a flare at the bottom. And the ride height should be low, but not so low you can't get in and out of driveways, etc.
    Paint should be black, no flames or such, with tinted windows.
  16. 19Fordy
    19Fordy
    No, you're not too old. It's a "generational" thing.
    40's look good no matter what the stance.
  17. Smart62
    Smart62
    from UK Sussex
    Hi Tyres look great what make and model are those tyres?
  18. Smart62
    Smart62
    from UK Sussex
  19. dirty old man
    dirty old man
    I must admit that my '40 coupe has a bit of a fwd rake, even though I have commented that I like them level or just slightly tail rake.
    But I didn't build it, I bought it that way and just don't have the desire to redo the suspension as it drives and rides great as it is;):cool:
  20. 47ragtop
    47ragtop
    Front 195/65 15's on 6 inch wheels and rear are 225/75 15's on 7 inch wheels. The front spring has reversed eyes and couple of leaves removed with stock axle. The grille chin has 5 3/4 inches of clearance. Grilles cost $$$$, so thats low enough for me. Later Bill
  21. 205/70R14 on front, 225/70R15 rear.
    Chassis Engineering rear with 2" blocks, CE dropped axle and spring on front.
    40FORDPU, 47ragtop and lothiandon1940 like this.
  22. i.rant
    i.rant
    from Illinois
    1. 1940 Ford
    Sent you a PM :D
  23. Moriarity
    Moriarity
    SUPER MODERATOR
    the fronts have since been changed to 5.90-15 and are bf goodrich silvertown bias plies from coker and I couldn't be happier with them
  24. nor6304
    nor6304
    from Indiana
    185-65-15 on 5" wheel 235-70-15 on 7" wheel BF Goodrich Silverstone also happy with them IMG_3619.JPG
