Projects 1940 ford coupe
Discussion in 'The Hokey Ass Message Board' started by deprice, Jan 6, 2014.
  1. deprice
    deprice
    I have a 40 ford coupe that has running boards with no covers.It has holes in it ,is this for the glue or what purpose are they for. Also what are the best covers and how hard to install.
  2. millersgarage
    millersgarage
    They are to let trapped air out during the process.
    I have never attempted putting new covers on.
  3. olscrounger
    olscrounger
    new covers can be installed and look fine if done properly. Need to go slow and follow instructions and avoid air pockets--have done a few sets,
  4. go-twichy
    go-twichy
    when they "molded" the rubber to the metal, the molten rubber would fill the holes keying itself in.
  5. rd martin
    rd martin
    from indiana
    as said you can install them yourself, take your time, bob drake has glue I have used worked well.
  6. sdroadster
    sdroadster
    Bob Drake is the best. Stay away from Vintique, fits poorly, made in China.
  7. 19Fordy
    19Fordy
    I agree. Go with Drake.
  8. Pewsplace
    Pewsplace
    I have used both Drake and Vintique and found that the Vintique products fit better than Drakes. Here are some photos.
  9. 19Fordy
    19Fordy
    I like Drake's because it has the lip that fits nicely over the bottom edge. Makes installation easier. I don't know if Vintique has that feature. Make sure the top surface of your board is "laser flat" and smooth otherwise imperfections will show. These were installed in 1988 and still on car.
  10. pasadenahotrod
    pasadenahotrod
    from Texas
    The adhesive is simple contact cement. Follow instructions and results will be good.
  11. I used Drakes as well. Lots of miles and they still look great. Had a buddy straighten the boards out before hand. The covers went on pretty easy.
  12. flamedabone
    flamedabone
    One of my favorite shots of one of my favorite cars. Your '40 was one of two cars I had in mind when I built my '39.
    By the way, I used Drakes covers on mine with no issue.
    -Abone.
  13. joel
    joel
    I have done Drakes also. I painted the blasted steel with DP 40 and used Pliopbond contact cement. An extra pair of hands can be very helpful.
  14. 343w
    343w
    Like the others have said, use the Drake ones with the bottom lip, and take it slow!
  15. 41FordVert
    41FordVert
    Sent my 41 Ford boards to a gentleman in Georgia to have the molded rubber put on as original process was carried out. Did a tremendous job.
  16. aaggie
    aaggie
    If your boards are not smooth or straight enough to use the repro covers just take them to a local place that does pickup bed liners and have them coated. It looks good and costs less than cover kits.
  17. I've seem this do in the past and in some applications it works but on a 40 Ford I don't think so.
    I have used the Drake covers in the past but prefer the look of the vulcanized running boards,,they never pucker and always look correct. HRP
  18. DD COOPMAN
    DD COOPMAN
    Hunley Acuff...the BEST! Click link below. DD
    http://hunleyacuffrunningboards.com/
  19. cryobug
    cryobug
    After you see how much better these look you won't want to use glue on covers ever again. I have had him do two sets for me. First class work
    Pricey but worth it
  20. 40fordtudor
    40fordtudor
    X2 on that extra pair of hands
  21. push_rod
    push_rod
    I've installed Drakes covers on my coupe, and dad's tudor with great results .
    As mentioned, make certain the surface of your boards is laser straight.
    My coupe had boards from two different manufacturers; one of them had very shallow raised ribs on the top surface that are slightly visible with the cover installed (I should have ground them away!). When I did dad's, I had to add a bit of bondo above the spot welded brackets because each spot weld had caused a low spot on the top surface.
  22. 40Standard
    40Standard
    from Indy
    open the tubes of glue, put them in a bag, smell it.......oh wait, it's not the 60's anymore.
    I like Drake's running board covers the best
  23. FOURTYDLX
    FOURTYDLX
    Mine are drakes
  24. 40 & 61 Fords
    40 & 61 Fords
  25. cryobug
    cryobug
    He charged me $800 for mine since they were already sandblasted
