Projects 1940 ford coupe build
Discussion in 'Traditional Hot Rods' started by newredporch, Jan 9, 2019.
  1. Jacksmith
    Jacksmith
    from Aridzona
    Regarding the clutch issue, There are a zillion ways to do it...
    My '39 Coupe was modified in the '60's with some sort of swing pedal configuration of unknown origin. It had an F-100 set up in it, it worked, so I retained it. I'm using an F-100 master/slave set-up with mounting brackets of my own design. (The mount that it had on it was a flame cut hunk of steel that looked horrible)
    The car has a '63 SBC and a Muncie 4-speed. (Soon to be a Tremec) The brackets mount to the threaded bosses on the block. The master mounts next to the brake master on the firewall. It works flawlessly and if I need repair / replacement parts, I can get them from NAPA. IMG_0154.JPG IMG_0157.JPG IMG_0160.JPG
    brEad and The 39 guy like this.
  2. newredporch
    newredporch
    from pittsburgh
    looks like a solid hydro set up.
  3. Jacksmith
    Jacksmith
    from Aridzona
    Yeah, I do tend to over-build stuff... German heritage... I did re-enforce the front strap with a length of angle iron after the first few times out. It bowed a little, but now it's fine.
  4. doubleduece
    doubleduece
    Nice build and some great information
    newredporch likes this.
  5. AHotRod
    AHotRod
    Your doing a great job!
  6. MtnTinker
    MtnTinker
    newredporch, Thank you for taking on a major Project and sharing your Adventures!
    Definitely not for the feint of Heart. But you are getting it Done, and Well Done!
    For a hydraulic clutch set up, I have used two brake pedals on the 39-40 shaft. The pedals are steel and you an heat them to tweak the right angle.
    I use the straight brake pedal for the clutch. This gives you two push shafts out the back. Then you can use a dual bore master cylinder like on the early 60s Chevy pickups or bolt a plate to the 3 bolt cylinder mount that will let you mount a two stage Master Cylinder for disk-drum brakes and a separate Clutch Master Cylinder.
    I have also used the early 60s Pickup Bell housing that mounts the Slave Cylinder on the passenger side. This opens up the drivers side for steering and exhaust.
    I've used the dual bore pickup MC on the Coupe in my Avatar since it went on the road in 86. It has disk brakes all around, so there is no residual valve in the brake side.
    Thanks for Sharing!
    Tinker
    The 39 guy likes this.
  7. newredporch
    newredporch
    from pittsburgh
    Sandblasted the back half and started boxing the rear rails. DBA12F4E-4986-4550-8948-64619975A93A.jpeg AEAE63E4-D006-47F8-B5C7-690C4296B285.jpeg A97A4724-EDEC-408D-8DBB-050B0A9086FA.jpeg
    40ragtopdown and brEad like this.
  8. newredporch
    newredporch
    from pittsburgh
    Good info! I have a mechanical set up that is almost ready to go. More on that later.
  9. MtnTinker
    MtnTinker
    Three Pedal Cars are Just FUN.
    The frame is coming along nicely!
    Keep on Posting. Thanks
    Tinker
  10. MtnTinker
    MtnTinker
    geoford41 has a pair on the HAMB classifieds posted on 11-19-29.
    Tinker
  11. newredporch
    newredporch
    from pittsburgh
    I’d like to thank Gary (40ragtopdown). He is a member and sells these cross members here on the Hamb. Good price, nice fit, quality part and he’s a nice guy. It sure did speed things up for my project. D4472C24-C79C-42A7-80B2-8BC2A8DA70C8.jpeg 769EF160-384A-4DC4-A740-FEDD16D974C3.jpeg
    32SEDAN, 40ragtopdown, brEad and 2 others like this.
  12. Nice parts. I agree, Gary is a good guy!
  13. johnold1938
    johnold1938
    from indiana
    mine from chassis eng. 1941 ford pickup build. IMG_0003.JPG IMG_0004.JPG IMG_0005.JPG
  14. newredporch
    newredporch
    from pittsburgh
    Moving along with the rear frame 59C6380E-62A5-4B70-986E-A68542997163.jpeg 4D4E8643-7591-4EBC-99E8-749EB754A0AE.jpeg 7239D87F-D15A-42DB-974F-BDE634BEB78E.jpeg 6652CA72-5506-4B96-9D44-BAD343EB3AC6.jpeg
  15. newredporch
    newredporch
    from pittsburgh
  16. newredporch
    newredporch
    from pittsburgh
    The posies spring kit says that the frame should be “C” notched. I feel like there is enough travel without. Does anyone have some real life experience on this? E72085E1-0838-4488-83F5-307A2F94B7EB.jpeg
    LOU WELLS likes this.
  17. That looks like a lot of travel. I have the CE kit and started with about the same and added lowering blocks. Not on the road yet. For comparison I have only 2 inches of travel on my 47 and it hits bump stops rarely mostly going over large bumps at highway speeds or crossing dips like drainage gutters. With 3 inches I'd probably never hit. I would not c notch with that much room. Dont forget the weight of the body will bring it down a lot but I bet you still will have over 3 inches.
    Sent from my SM-A102U using The H.A.M.B. mobile app
  18. newredporch
    newredporch
    from pittsburgh
    This picture shows it hanging. When it was sitting on its wheels, it still looked ok to me. My model A used to hit hard at times and I hate that. I might just notch it to be sure. I dunno
  19. okiedokie
    okiedokie
    from Ok
    I have overload bump stops on my 40 with CE rear springs. I believe that I bought them from Eaton Spring but that has been several years ago. I have been pleased with their function.
  20. Dak Rat
    Dak Rat
    from NoDak
    Have that kit in my '39 convertible. If you have the springs in the lower bolt hole (front mount) you will not need to C-notch the frame. I have never hit the bump stops with my car.
  21. newredporch
    newredporch
    from pittsburgh
    Thanks for the info. Not sure which hole I mocked mine up on. At that point in time I wasn’t even thinking about a notch.
  22. alchemy
    alchemy
    I think your car will sit like a four-wheeler unless you do something to get it lower. Years ago our 40 coupe had about an inch before it hit the rubber bumpers in the back. That stance looked about right to me. If we had it to do over again I'm sure we would have C notched the frame for a bit more clearance.
    Actually, on a car like a 40 where nobody will see the frame rail, a squareish notch might be better so you could still mount a rubber bumper up in there.
    anothercarguy likes this.
  23. krylon32
    krylon32
    from Nebraska
    1. Central Nebraska H.A.M.B.
    I have the standard CE rear spring kit on my 40 with 2 inch blocks and have no issues. Car sits nice.
  24. newredporch
    newredporch
    from pittsburgh
    I think I’m gonna notch it
  25. golferforpar
    golferforpar
    from Wisc
    I'd like to echo what "newredporch" stated regarding Gary (40ragtopdown).
    I purchased the center crossmember kit that he manufactures for my 1940 Ford pickup project. I also purchased his rear leaf spring kit. High quality, cost effective, and Gary was always available to answer any questions. Very cordial, patient, friendly, a nice guy.
    The 39 guy and newredporch like this.
  26. newredporch
    newredporch
    from pittsburgh
    After a full day of welding, I think I am pretty much done. Weather permitting, I will get it blasted and ready for primer this week. BE1C4D93-4DAD-4D9D-B746-9D524693ADFC.jpeg BBE80EB3-86AA-4B14-B96B-D92021145D96.jpeg
  27. Bandit Billy
    Bandit Billy
    I like reading along on your build. I have nearly the same CE set up in back as you on my 41 PU. Installed inside the frame up front and in the frame in back like you did. I installed bump stops that you can see here barely.
    This is the profile after driving with no lowering blocks and close to weight. The only thing missing is bumpers and bed wood in back. I am quite a ways off the bump stops still. I think you will be fine.
  28. newredporch
    newredporch
    from pittsburgh
    I think you are right. If I have to notch it later, I will. For now I think I will leave it alone.
    Thanks for your help! Happy building.
    Bandit Billy likes this.
  29. us054382
    us054382
    Hey Red, I have the same Posie rear suspension kit in my coupe, set to the lower setting at the front perch (upper bolt hole). I wish I had notched the frame when I had the chance, because I do bottom out with bad dumps. The ride and handling is better than my experience with CE rear kits (no need for lowing blocks). Perhaps the PU are lighter at the rear to where the notch won't be needed. Good luck, nice looking project.
  30. newredporch
    newredporch
    from pittsburgh
    good real world info. Maybe I should hack into it before I paint it. It would probably gain me 1” of travel.
