1940 Ford clutch expert wanted
Discussion in 'New to the H.A.M.B.? Introduce yourself here!' started by LUCKY R, Jul 1, 2012.
  1. LUCKY R
    LUCKY R
    from Denver
    Looking for help,1940 Ford 221/3 speed
    New flywheel, preasure plate, throwout bearing,parts are correct to this car. I have 5'' top pedal play with adjustment all the way out and forks barely touch throwout bearing ? could the rest of the clutch pedal assembly be so worn out to cause this. ? ( PS I am new to this site and trying to navigate around ) any help from a expert. CR
  2. DD COOPMAN
    DD COOPMAN
    Clutch pedal assembly is quite likely NOT your problem. Almost sounds like either the wrong clutch assembly itself (where the three clutch arms end-up being spaced too far away from the throwout bearing), or the throwout bearing itself may be too short (too thin when measured front to rear), or possibly even a combination of the two mentioned wrong parts (not likely). DD
  3. 40FordGuy
    40FordGuy
    Ditto, DD Coopman,...... 5" is way too much free play. You said "new flywheel", "new pressure plate",...What about the disc ? Another thought...is the pin that secures the release fork to the cross shaft broken ?
    4TTRUK
  4. 40FordGuy
    40FordGuy
    Ps; NOT an "expert"........
    4TTRUK
  5. LUCKY R
    LUCKY R
    from Denver
