Projects 1940 Chevy Sedan SEGA Gasser Build
Discussion in 'Traditional Hot Rods' started by CPT_Kill_Roy, Jul 10, 2019.
  1. CPT_Kill_Roy
    CPT_Kill_Roy
    I flipped one of my rear springs around and it centered my rear axle. Thanks to who ever gave me the idea.
    brEad, swade41 and Crkrjac like this.
  2. 1971BB427
    1971BB427
    from Oregon
    Now the real trick will be getting the back end lower with the stock springs! Are yours the 8 leaf packs like my '39 coupe were? If so you might get away with removing about half of the leafs and maybe get it low enough. Here's mine with just the main leaf, and 4 leafs from a '55-'59 Chevy truck front axle.
    CPT_Kill_Roy likes this.
  3. CPT_Kill_Roy
    CPT_Kill_Roy
    Yep it’s got the big 8 leaf pack.
    I’m not sure where it will sit. It was on a jack stand in the photo. Im also rebuilding the bushings and shackles. I’m going to run The 29.5” towel city pie crust slicks, or M/T 29x12.5 tires. I’m also looking at those floater axle spring mounts. They look like the ride height can be adjusted.
  4. 1971BB427
    1971BB427
    from Oregon
    Floaters will give a small amount of adjustment, but not enough to make up for those springs. The Tri 5 Chevy springs are flatter, and lowering springs for the same are flatter yet. In addition to the change in springs on mine, I also welded a 1" box tube to my spring perches so it lowered the rear another 1". A total of about 3.5" lower than it was.
  5. CPT_Kill_Roy
    CPT_Kill_Roy
    Are the Tri-5 springs 2” wide?
  6. 1971BB427
    1971BB427
    from Oregon
    Sorry, the '55-'57 are 2". You need '54 or earlier if you want to stay with 1.75" width. But if you keep your 1.75" main leaf you can stack the 2" leafs on top of that to make a pack. That's what I did and it works great. Just need to get 2" spring clips to strap the new pack together.
  7. CPT_Kill_Roy
    CPT_Kill_Roy
    I think swapping over to 2” springs is a good idea. I need to redo the spring perches any way. The pinion angle is way off.
    Dyce likes this.
  8. CPT_Kill_Roy
    CPT_Kill_Roy
    I found a guy south of Portland that has stacks of Tri-5 leaf springs. I can have a set for $25 he said there’s 2 different types some have more leafs.
  9. CPT_Kill_Roy
    CPT_Kill_Roy
    Got a few things done today. Skinned my trunk lid and added pins. IMG_3793.JPG
    Took my top loader out of its crate and it looks like I’ll be making custom shift rods for my V-gate shifter.
  10. CPT_Kill_Roy
    CPT_Kill_Roy
    I’m putting together a set of custom Delrin bushings for my rear springs at the frame hanger. Zero deflection, super solid, and their smooth as roller skate wheels. Adjustments.JPG
    Crkrjac and brEad like this.
  11. Crkrjac
    Crkrjac
    from Waxhaw NC
    Good seeing progress!
    Keep at it man!
  12. CPT_Kill_Roy
    CPT_Kill_Roy
    There’s allot going on with the Engine build. The tunnel ram is getting flowed and matched to the big valve 781 heads. IMG_4487.JPG
    swade41, Crkrjac and brEad like this.
  13. CPT_Kill_Roy
    CPT_Kill_Roy
  14. Crkrjac
    Crkrjac
    from Waxhaw NC
    Some good looking stuff happening
  15. Nice car! I used a big journal 327/T-56, 6 speed/9" in my 40 coupe with mustang style front. Chassis engineering makes nice suspension for the rear. An anti-sway bar is available.
    White Salmon, eh? I was born and raised in The Dalles. I really miss the gorge. 40chevand41poncho.jpg 40chevyatjimmys11-18-05P1010010.JPG 40chevyminusquarter.jpg
    swade41 and brEad like this.
  16. CPT_Kill_Roy
    CPT_Kill_Roy
    I have a 1967 small journal 327 but I didn’t think it would have enough power. So I went with a BBC 467.
    I think I’ll keep the 327 for my next project.
  17. CPT_Kill_Roy
    CPT_Kill_Roy
    Time to start doing some wiring. I got this Speedway harness of eBay for a discount. The original harness way rotten and useless. IMG_4607.JPG Adjustments.JPG
    brEad and Crkrjac like this.
  18. southcross2631
    southcross2631
    I am not using my Hurst inline shifter . Here's what the rods look like. It's for a top loader. DSCF3581.JPG
  19. Bob Lowry
    Bob Lowry
    CCOL CAR!! Had a '40 Chevy Coupe when I was 16, built it all in the carpot. Use a '55 Chev. rear end..easy fit!
    The entire front body bolts together, so I made a tilt front end on it just using simple hand tools and a drill.
    292", tunnel ram, magnesium American mags...Hugger Orange...perfect for 1966...you can put C-channel
    between the front cross member and the rails and raise it up however high you like without changing the
    alignment geometry...5 lug hubs from a later passenger car are a direct fit, too. Fun project!
  20. CPT_Kill_Roy
    CPT_Kill_Roy
    I was looking around this old grain bin for some scrap pipe to build a bumper. I ended up finding a grain auger that’s inside a 4” pipe. It looks exactly like one of those muffler inserts. IMG_4364.JPG
  21. CPT_Kill_Roy
    CPT_Kill_Roy
    I have a few Items that will be added to the dash. I plan to use an additional amber colored light and wire it as a shift light. The toggle and red lamp will be for the ignition, starter, and fuel pump. IMG_4618.JPG
    brEad likes this.
  22. CPT_Kill_Roy
    CPT_Kill_Roy
    Found some dirty old mags. Wish me luck. IMG_4655.JPG IMG_4654.JPG IMG_4656.JPG
  23. zjerry
    zjerry
    59952731_1238962066279140_3958269953374683136_n.jpg 64836429_1535480393254249_3736112976147513344_n.jpg A few pic. of my 1940 chevy
    48fordnut and loudbang like this.
  24. Quain Stott
    Quain Stott
    You can build your floaters to be adjustable. If the housing is mounted on top the further away you get from the spring the lower the car will set so it should be easy to get it to set where you want even with the full spring pack. Then just take out springs to get the spring rate you want. I included a pic of how I make them, been making them like this since the mid 1970's, real simple and they work great. Let me know if you need anything. floaters.jpg
  25. 1971BB427
    1971BB427
    from Oregon
    Just a note on those ET slots. The washers for the lugnuts come as shank style for mag wheels, or conical like steel wheels use. Be sure to get the conical washers, and not the shank style! I've used them with shank style washers and had them work loose! Nearly lost a wheel on my car when it happened and it went from feeling nothing to almost falling off in a couple blocks! Switched to conical washers, and nuts, and it's been great for many years!
    Crazy Steve and loudbang like this.
  26. 56sedandelivery
    56sedandelivery
    When I first started reading this thread, the car I thought of is of the photo posted by swade41, the light brown/tan 4 door sedan I've seen run many times over the years. AND, it's a STREET CAR to boot! The very first job my younger brother got, straight out of college, was with the State of Washington in White Salmon, some 25 years ago. Now, he and his wife (a White Salmon girl), live in the big city of Port Angeles, Washington. I'll be watching this build.
    I am Butch/56sedandelivery.
    Lloyd's paint & glass likes this.
  27. jimmy six
    jimmy six
    Firewall needs look like this. 87B8935E-E0DA-4B20-A152-579918EAEC56.jpeg E2004CAD-15BC-4914-880C-FD6522E3DCE9.jpeg
