Projects 1939 packard 120
Discussion in 'The Hokey Ass Message Board' started by ilff618, Sep 1, 2012.
  1. ilff618
    ilff618
    does anybody know what front end will fit on a '39 packard 120? PS,PB, IFS
  2. kornbinder
    kornbinder
    from Sonora, CA
    A friend of mine has a 120 convertible coupe and put it on a 2WD half ton Suburban frame
  3. ilff618
    ilff618
    do you know what year?
  4. rainhater1
    rainhater1
    from az
    our 41 110 has a 80's corvette clip with air and it is great.
  5. samurai mike
    samurai mike
    i put a 1969 buick skylark clip in mine, but it's drum brakes.
  6. harleyjohn45
    harleyjohn45
    I did a 38 packard, made a mess out of it. I was talked into using an S-10 front end with an Izusu rack. The steering was twichy, finally got a valve like they use on mustang 2, and it helped. I understand a 67-68 camero front end will work. If I was doing it again I would keep the packard front end. It has independent front suspension with coil springs. way ahead of its time. Power brakes with a vacuum cannister is doable, and I understand some of the folks are modifying the steering to power steering.
    I subframed mine, the S-10 frame was exactly the same. Only took a few minutes to weld it on. Could not use the S-10 steering sector, because it stuck out too far. good luck.
