Fresh from the June 2018 Greenwich Concours! This 1939 Ford Deluxe Coupe was built be well know Hot Rod expert Jerry Hagens -- author of "Full Race Flahead " Jerry is a well know old school hot rod builder. He chose the theme to be a period correct early fifties moonshine car choosing a traditional 1951 351ci Cadillac built to high performance levels using rare Eldorado dual quad intake feeding into big port Eldorado heads and exhaust manifolds. Power is driven though a rare (one year only) vintage 1937 Cadillac / LaSalle 3 speed floor shift transmission. Just refreshed with engine out with receipts including: - removing the engine and transmission for refresh - inspected all trans gears / bearings / syncros and resealed the LaSalle transmission (leak free) - new clutch and TO bearing - rebuilt clutch linkage - new front and rear engine main seals - new valve cover gaskets - complete tune-up - installed custom drain bung on differential and replaced posi fluid - rebuilt emergency brake assembly - adjusted brakes - rebuilt the 39 steering box with new worm/sector gears and new seals - fresh alignment - new steering column top bushing - NOS new original 1939 Ford Deluxe Speedometer installed The Coupe looks right, sound right and drives right! - comes with a complete 2 inch thick build book with the history of car, the builders, build pictures, all receipts Stock Unmolested Body and Interior Original all steel un-chopped or modified Fords are getting harder and harder to find. Jerry kept it original and did the body work using the hammer/dolly method to smooth any dings and imperfections. Painted was applied by Todd James of Rats Rides -- Bradford, Tennessee. Interior Interior is stock LeBonny Baron. Stock dash and instruments. Original Ford Heater, B29 WWII restored Bomber Belts, NOS 1939 Ford Deluxe Speedometer, battery cut off, period correct turn signals Drivetrain 1951 Cadillac 331 ci bored to 365cu and a 1937 LaSalle 3 speed top loader floor shift. Ron Williams of Auto-Ron's - Davenport Iowa built the engine. Magazine article about Ron is included. All receipts and build details are included. Engine Detail - 275hp/344 ft lbs at the rear wheels - dyno reports included 1951 Cadillac 365 cu in (bored from 331ci) 4" JE forged pistons Stock Crank and rods Eldorado dual quad intake - WCFB Carter carburetors Eldorado big port heads Eldorado exhaust manifolds Eldorado "Batwing" Chrome intake air cleaner Chrome Cadillac valve covers Nielson Vintage Racing Cam - 432 lift/282 duration (Cam specs included) 2" dual exhausts 11" Weber Clutch 1937 LaSalle 3 spd (one year only floor shift!) Front Suspension - 4" dropped front axle (NOS Cragar) Rear Suspension -- 2 " drop - Chassis Engineering rear suspension Chassis Chassis Engineering parallel rear springs 9" Ford 3:50 rear plus traction bars Custom open driveshaft with front yoke slip joint 5.5 bolt pattern wheels all around .5.5" front - 1950 Mercury 6" Rear - 1950 Lincoln 41 Lincoln Front Brakes
