A complete frame restoration took place in 1994 with the following modifications -Mustang 2 front clip, with rack & pinion power steering and power disc brakes -Chassis Engineering motor mounts and transmission cross member mount -Chassis Engineering parallel leafs under airbags, rear suspension, CE sway bar -Ford 8 inch rear axle with 3.55 gears -Tanks poly fuels and sender -Chevy 350 ci, with performance cam,Wei and aluminum intake, Holley 600 cfm carb and GM ram horn manifolds. 2 inch exhaust through Dynomax Turbo's -TH 350 Automatic Transmission with shift kit and frame mounted cooler -185x14 and 235x15 rubber mounted and Cragar SS wheels ------------------------------------------------------------------------------------------------------ -Body stripped of all paint, stainless body trim removed -Custom steel smooth running boards -Front and rear bumper bolts welded and smoothed -Sikkens base/ clear red with custom flames -Halogen headlamp conversion -New mirror -New front windshield glass -Pertronix Electronic Ignition ----------------------------------------------------------------------------------------------------- -Grey velour interior, with 6 way power bucket seats - Original dash, with hidden supplemental digital gauges -Lokar nostalgic floor shifter -Original banjo steering wheel , leather wrapped -Power windows, opening front windshield and cowl vent -Remote power door locks -Sony CD player and alarm system -Dakota digital cruise control -Custom trailer hitch -New Bridgestone tires and allignment -New driveshaft and U joints -Digital gauges, supplement original dash gauges -New battery Sept. 2011 Car has had recent MB Safety $26,900 USD No emails please, call or text 204-290-0344
