1938 ford 4 speed
Discussion in 'The Hokey Ass Message Board' started by devotion, Dec 10, 2012.
  1. devotion
    devotion
    from idaho
    Picked up a 4 speed to put behind a 38 flathead the other day... I know it's not the desirable 3 speed, but what can I expect with it? A really low first gear I'm assuming... What about the other 3? It has stock gears in it
  2. devotion
    devotion
    from idaho
    Rear end is a 48 banjo with 3.54 gear ratio
  3. Hnstray
    Hnstray
    from Quincy, IL
    It's a truck transmission and offers nothing over a stock 3 speed passenger car trans from the era for a street driven automobile. In my opinion, it is a liability because of it's weight and bulkiness.
    I would recommend either a floor shift '39 style or side shift '40 through '48 trans.
    Ray
  4. Saxon
    Saxon
    from MN
    What to expect. Well 4th is 1:1 like 3rd on a three speed. Not sure all actually gear rations. 1st is a stump puller and you won't use it much, if ever. So not much difference till it comes to shifting. If the early 4sp then no synchros, they are spur cut gears (some synchro'd 4sp's after 48). Get used to double clutching or slow shifting. I have one in my truck and I actually like it. But my truck isn't a hotrod. It's a truck.
    Parts drawing for ID help of your trans.
    http://www.vanpeltsales.com/FH_web/flathead_drawings_trans.htm
  5. devotion
    devotion
    from idaho
    That's the advice I'm looking for. If thank you. If I built the car with this transmission and later on down the road decide to swap out gears is it possible?
  6. Saxon
    Saxon
    from MN
    I wouldn't put the 4sp in a car. sorry. I'd look for a 3sp. Not that you couldn't... but I think you'd be better off being (I'm assuming) it's all torn apart now. If it was a truck, i'd say go for it!
  7. Hnstray
    Hnstray
    from Quincy, IL
    If the trans is the same length as the 3 speed and is also a torque tube style connection to the driveshaft, then, yes, you could swap it out later.
    But why do the work twice?
    Ray
  8. greaseyknight
    greaseyknight
    from Burley WA
    I don't believe their are any different gearsets available for it. Its a spur gear transmission, more like what you would find in an 18 wheeler then anything else. So you have to double clutch going both up and down the gears. I've also found there to be quite a gap between 3rd and 4th, with the 3.54 rear in my truck. Kinda a pain when driving around town. All this is presuming that you have a Warner T-9 :)
    The ratios are:
    1st=6.4
    2nd=3.09
    3rd=1.69
    4th=1.0
