Projects 1937 Plymouth Build Thread
Discussion in 'The Hokey Ass Message Board' started by 56 Dodge Pickup, Jan 29, 2015.
  1. Mudgy
    Mudgy
    great work, Jim. Looking great mate
  2. Nice build. Looks awesome
  3. 56 Dodge Pickup
    56 Dodge Pickup
    1. H.A.M.B. Chapel
    Thank you Michael do you have a build thread?
  4. 56 Dodge Pickup
    56 Dodge Pickup
    1. H.A.M.B. Chapel
    Well the upholstery is finally done now back to the metal work although there will be a delay the shop that I get my metal from was closing when I arrived so no metal until after the fourth. That's OK I still have plenty to do. Thank you for looking Hobo Jim
    1947knuck likes this.
  5. 56 Dodge Pickup
    56 Dodge Pickup
    1. H.A.M.B. Chapel
    Here is the latest update I just got my carburetor rebuilt by a good friend and I installed my signature copper pipe radiator hose. The engine is know ready to run I just have to pick up a battery, then it will be time to make some noise!
    I have also have completed the seat frame and the upholstery and the most important adjustment the elbow on the door comfort height. I am know working on the metal frame for the seats stay tuned. Hobo Jim
    1947knuck and Dog_Patch like this.
  6. 51cambridge
    51cambridge
    Wow looking good
  7. 56 Dodge Pickup
    56 Dodge Pickup
    1. H.A.M.B. Chapel
    Thank you 51 cambridge are you going to Hickory on Sunday? I am thinking of going down for a while. Hobo Jim
  8. 51cambridge
    51cambridge
    Yes weather permitting
  9. 56 Dodge Pickup
    56 Dodge Pickup
    1. H.A.M.B. Chapel
    After a fantastic weekend at the Syracuse Nationals I went back out to the garage to work on the Plymouth I made the seat back bead rolled the top contour and made a 30 degree bend to follow the seat back. I also welded some 90 degree brackets on the side panels so I could attach the back of the seat. I am going to use solid rivets to attach the panels installed the traditional way using a buck bar and a ball peen hammer. Here is a pic of the seat back clamped to the sides.
    The bead roll contour lined up great this will be a nice detail when this is finished.
    1947knuck and tb33anda3rd like this.
  10. 56 Dodge Pickup
    56 Dodge Pickup
    1. H.A.M.B. Chapel
    In keeping with my ultimate goal on this project by doing as much of this build in my garage and in the most traditional way possible I obtained some solid rivets for back in the 30's or 40's then I made a buck bar from a piece of angle iron used a heal dolly that I ended up taping to the angle iron so that it was easier to hold.
    Here the results of a lot of hammering I think they are coming out Great and very traditional look just what I was looking for!
    Here is the outside I will be installing some more soon.
  11. 56 Dodge Pickup
    56 Dodge Pickup
    1. H.A.M.B. Chapel
    More progress today all the riveting is completed and the trial fit is really good still needs finishing but it is really coming together nicely.
  12. 56 Dodge Pickup
    56 Dodge Pickup
    1. H.A.M.B. Chapel
    The seat is really coming together nice finished the brackets tonight and I was finally able to sit in for a test the seat fells Great! Still have to finish the metal work, but I am very happy and impressed with the way this is coming out. Hobo Jim
    Yes I did make motor sounds Ha Ha sure did feel good to sit in the drivers seat listening to Rock a Billy
  13. 56 Dodge Pickup
    56 Dodge Pickup
    1. H.A.M.B. Chapel
    Worked on metal finishing this evening seam is really coming out tight after some hammer and dolly work and a little finishing with the die grinder it looks really good in my opinion.
    This a picture of the seam before the metal work you can see the wide gap.
    after the hammer and dolly work same seam you can see the gap that hasn't been metal finished on the bottom
    Same seam after finish with die grinder nice and tight now thats what I am talking about nice quality finish I am very excited to have bomber seats in this car something I wanted to do from the first day of the build. This seat was very challenging to build I learned a lot.
  14. 56 Dodge Pickup
    56 Dodge Pickup
    1. H.A.M.B. Chapel
    Well it has been a long process and very enjoyable, but the fabrication is completed on my bench bomber seat. Here are the finished pics it still needs prep for paint but I am very happy with the results I hope you enjoy them.
    Here is a close up of the cover plate that I made to cover the bolt that the back of the seat pivots on I used copper bushings and brass screws to stay with the period look. I had a lot of time in these covers making the dome high enough to clear the bolt head and the contour tight to the side panel, but the end result is a really cool looking detail.
  15. 56 Dodge Pickup
    56 Dodge Pickup
    1. H.A.M.B. Chapel
    Had the motor running tonight for the first time!! Super excited that's a major milestone on the build. Looking forward to the first ride!! Hobo Jim
  16. classiccarjack
    classiccarjack
    Wow, you are great with your hands! This is so inspirational! Thanks Jim
    Sent from my XT1585 using The H.A.M.B. mobile app
  17. 51cambridge
    51cambridge
    Great work!
  18. 56 Dodge Pickup
    56 Dodge Pickup
    1. H.A.M.B. Chapel
  19. 51cambridge
    51cambridge
    We will be at Tioga Downs
  20. 56 Dodge Pickup
    56 Dodge Pickup
    1. H.A.M.B. Chapel
    I think I will be there also looking forward to seeing you and having a Great Time!! Hobo Jim
  21. 56 Dodge Pickup
    56 Dodge Pickup
    1. H.A.M.B. Chapel
    So after a year of thinking and searching every flea market I could find I have finally found a headlight bezel that I like. Last winter I bought a box with 30 random bezels for five bucks I went thru them a couple of weeks ago and I found the perfect bezel go figure I only had one and also there was no indication as what car it was off, the search continues. I was at the Watkins Glen vintage races when I saw my mystery head light bezel it was on a 1956 Jaguar. I posted on the HAMB for some help and with minutes Prewarcars4me responded with a lead on a set on ebay Thank you!! a couple of clicks later and they were on there way! I just finished the install here are some pics for anybody looking for a really cool looking ring that fits the headlight bucket like a glove check these out.
  22. Mudgy
    Mudgy
    They are a good match Jim.. How are you going to attach them?
  23. 56 Dodge Pickup
    56 Dodge Pickup
    1. H.A.M.B. Chapel
    Hey Mudgy really good to hear from you! The bolt hole on the bottom of the headlight housing lines up perfectly with the bezel just have to bend a 90 out of sheet metal then bolt on. I made another piece of sheet metal that fits inside the top of the bezel and is bent so that it holds the top like a spring. I can post some pics tomorrow I am amazed at how well these fit. I think I am going to make an arrow to pull down the headlight bucket from the bezel Jaguar had one on there headlight I just don't want to pay the price and it's more fun to make my own!
    Thank you 51 Cambridge for the like I hope to see you this weekend at Tioga Downs. Hobo Jim
  24. 56 Dodge Pickup
    56 Dodge Pickup
    1. H.A.M.B. Chapel
    OK Mudgy here is a couple of pics of the clip made to hold the top of the headlight bezel in place pretty simple made out of 26 gauge sheet metal
  25. Mudgy
    Mudgy
    Thanks Jim, you gave me some ideas mate. I got a message from admin today... my build thread has gooone.
    Oh well, onwards I go regardless. No big deal , really.
    Cheers Mudgy
  26. 51cambridge
    51cambridge
    Not sure if i can make tioga downs:(
  27. 56 Dodge Pickup
    56 Dodge Pickup
    1. H.A.M.B. Chapel
    OK so every year or so the garage finally gets to dirty and cluttered for even me today was that day. I took the Plymouth of jack stands for the first time in over a year I forgot how the stance looked I was impressed and motivated to get some other work done.
    How do you like my wheel choke? It was the closest thing I could find. Ha Ha!
    I then decided to install the fenders naturally this turned into unexpected rust repair. Oh well its just another excuse to do some more metal work instead of cleaning the garage.
    That metal glue sure does make the installation quick. Nothing to exciting but it sure was nice to see the 37 on the ground!
  28. 51cambridge
    51cambridge
    Wow, taking shape
  29. 56 Dodge Pickup
    56 Dodge Pickup
    1. H.A.M.B. Chapel
    51cambridge likes this.
